Question about Radio Communications
3.5mm jack got crushed between bmx chain and cog
  • 422 Answers
Get a replacement from element14 or farnell or any electronics store.
split the cables and solder them
Posted on Oct 16, 2013
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Bmx 4 wheeler
the rear wheel is the adjustment. loosen the main axle bolt and slide the wheel back until chain is tighter. if it has rear suspension there should be a small amount of slack in the chain when done. retighten axle bolt.
Sep 06, 2013 | ATVs
Back wheel cog
the gear that needs to be replaced requires a special tool. You can get one online whereever you buy the gear you should also be able to purchase a splined socket to assist in getting the old one off of the hub. Might I suggest ebay.com?
May 11, 2013 | Mongoose 20-Inch Gravity Games BMX...
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
I need to know how to take a chain off without breaking it please
Pull the chain out slightly, away from the bicycle frame, at the bottom just behind the front cog wheel (attached to the pedals). While holding it out turn the pedals backwards and the chain will come off.
Sep 04, 2010 | Huffy BMX 20" Boy's Rock It Bike
My rear chome whheel squeeks when i break
Thats a sign that you need your brakes checked or adjusted.
Jun 09, 2009 | Dell Dimension BMX Cassette hub 48h...
Front cog does not rotate when pedaled
You will have to remove the rear wheel and take it in to a bicycle shop and have the rear cog replaced. The freewheel part inside it has likely broken and will only rotate in both directions. It should rotate to back pedal and then catch as you pedal forward.
Apr 08, 2009 | Freestyle Cycling
Slipping while cranking
The rachets in the rear gear cog have gone bad.  Buy a new gear cluster and have it installed on your rear wheel.  about $30
Mar 26, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
When i push on the pedals the backwheel doesnt go around
You my friend have a stripped free wheel.  The only solution is to get a new free wheel or just go out and get a new rear wheel all together.
Feb 14, 2009 | Dell Dimension BMX Cassette hub 48h...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
