Question about LG Optimus 3D
My wifi and bluetooth not working - LG Optimus 3D
Mac-address wifi unavailable and bluetooth address unavailable.
- go to data/misc/wifi (required root)
-backup file wpa_supplicant.conf in this folder which contains usename and password wifi
- delete all file in this folder
- turn on wifi ( if you careful, you can reboot )
- now you can connect to wifi
- recovery file wpa_supplicant.conf
Sep 12, 2016 | Huawei P8 Cell Phone
Bluetooth not working in dell latitude e 4300
Dr Sandeep Mayall/ Sandy,
Make sure it is on as well as turned on in the bios.
Try reinstalling the drivers for your wifi/bluetooth. You can click the link below to download the drivers.
Latitude E4300 Drivers and Downloads
http://dell.to/1VVFPlg
Thank You,
Dell-Jesse L
Apr 27, 2016 | Dell Latitude E4300 13.3" Laptop 2.4GHz...
Cant connect to wifi because bluetooh is stuck running a prograhm
You can turn off BlueTooth by either going to Settings-->Bluetooth, or touching the BlueTooth icon in the Control Center (swipe bottom to center to bring up the Control Center).
Test your WiFi. If it doesn't work, double-click the Home button, locate the program BlueTooth is running, and swipe it to the top of the screen.
Test WiFi again. If it doesn't work, power down; wait 5 minutes; and power up your phone (if you don't see the white Apple icon when powering up, you did not power down properly).
Feb 15, 2015 | Apple Iphone 4s I Phone 4 S Factory...
Acer travelmate 4000
You'll need to select a wifi network to connect to. Also, bluetooth doesn't work that way, bluetooth is used to connect 2 devices to share files, it does NOT give you access to the internet
Jan 27, 2014 | Computers & Internet
Wifi is grayed out
Turn off Bluetooth in settings and then tap wifi turn off then back on. Wifi should now be working
Jun 21, 2013 | Computers & Internet
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
I m not able to connect to bluetooth and wifi please help!!!!!!!!!!
Your dell bluetooth must be turned on before able to pairing with other compatible device. Please check bluetooth switch on your laptop keyboard ( if there is you must turn it on also). Most of bluetooth devices are compatible.So please try again your bluetooth pairing .
To activate the wifi , you must covered at active wifi area / Wlan ( hotspot), then click your internet connection on right below corner ( beside battery sign) and open network and sharing center,then activate your wifi . This wifi will not work if you are outside wifi covered area.
Regards
May 14, 2011 | Dell Vostro 1014 Laptop Computer
No user manual with new little MSI netbook. Need to know how to enable wireless network. Is there a switch or key combination?
Try this:
FN+F11 turns wifi/bluetooth on/off
Look at the LEDs on the front, namely the left most two.
No Blue + No Green = All wireless modes off
No Blue + Green = Bluetooth Off, WiFi On
Blue + No Green = Bluetooth On, Wifi Off
Blue + Green = Both Bluetooth and WiFi on
Press Fn+F11 to switch between each mode in turn in the order above.
Configure your wifi access with whatever tool you prefer. Some use the built-in windows wireless network , others use the realtek one. Use whatever works for you. (personally, I use the windows one).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 28, 2008 | Computers & Internet
Since upgrading windows XP to service pack 2 my Acer Travelmate 290xci the bluetooth and wifi doesn't work. The view networks doesn't do anything and no networks are detected
the bluetooth and wifi of your laptop is not working after you upgrade your system to windows xp this is due of driver problem you need to instal the updated driver/software of your bluetooth and wifi that is compatible for windows xp....
Aug 09, 2008 | Acer Computers & Internet
Pocket PC e400 en Sandisk WiFi
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
Sep 11, 2005 | Toshiba e400 Pocket PC
LG Optimus 3D Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
