Dv2000 all th screen becoming white no data - Computers & Internet
    Top Expert:
  • 12,223 Answers
Use another monitor for to test if the monitor are o.k the screen has been faulty. repair.
If Not the video card has trouble. fix it.
God bless you
Posted on Oct 16, 2013
No data hp
video is bad need to replace it
Aug 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
When i turn on My hp pavilion dv2000 the blue lights turn on but the screen stays black
It is possible that the problem in the slide card that beats screen located on the main board and the faults which also appear on-screen plasma appearance of a white image on the screen or the colors are without any data. Easy to verify the integrity of the slide card that beats the screen by pressing of Touch Pad or the left part of Keyboard to the East, including notes. When connecting to an external monitor with no emergence of data
Among these symptoms we see that it is clear that the device temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
May 18, 2013 | Computers & Internet
One inch white line when booting slowly becomes solid
If you'r not expert fixing laptops send it to repair shop to check screen cable it might be screen data cable problem like it loose or need replacement if this not the problem then Ohhh time to change the screen...Good Luck
Feb 03, 2013 | HP Pavilion zd8000 Notebook
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
My HP Pavilion dv2000 laptop screen fades to white, sometimes comes on white, and I wiggle it to get it on. Sometimes restarting the screen helps.
Sounds like you have a loose connection either on the flat video cable on the left side of the motherboard or the inverter cable on the right side of the motherboard that supplies voltage to the screen. Below is a manual for disassembling the laptop down to where you can inspect and reseat the cables.
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Nov 12, 2009 | Sony VAIO VGN-CR115E/P Laptop
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
Driver Problem
Jan 28, 2009 | HP Pavilion dv2000t Notebook
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
AG-DV2000 output is black & white only -- no color?
I fixed it! It was a menu option that could only be changed using the remote. (I never use the remote)
Q: Why did it change from color to black & white to begin with?
A: Maybe when I unplugged the unit to move it after 8 years of being in the same place.
Sep 06, 2008 | Panasonic AG-DV2000 Mini DV VCR
Blank white screen
The problem with this handset is its data cable which connect your mobile screen to your mobile mother board. When you slide up and down, the data cable get destroyed and your screen display and sound problem get started and after some time when data cable get cuts it stop passing th current from *********** board to screen so this happen. To get resolve you need to change that data cable from service centre. But I would suggest you to go for other mobile because this is the main problem with this model of samsung . I would suggest you plz not waste your money in this handset "because of the same problem company has stopped the pruction of this handset".
Aug 26, 2008 | Samsung SGH-D840 Smartphone
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
