Question about Electrolux Freezers
Freezer won t freeze - Electrolux Freezers
    Problem Solver:
  • 17 Answers
Probably the defrost timer and limit switch
Posted on Oct 19, 2013
We unplugged myhaier freezer to move it .Now it won't come back on.It is getting electricity
your connection on freezer is get directly,you do not connect arthin wires which save freeze to any electricity problem.
Mar 15, 2013 | Haier Freezers
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Freezer gets to cold thermostat won't adjust
Prepare to replace the t'stat. At least it is freezing and you haven't lost anything.
Jan 26, 2013 | Kenmore Elite Side By Side Refrigerator -...
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Freezers Logo
80 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
