Hp slate7 tab discharges instead of charging whilst charger is connected
nitrospawn
  • 290 Answers
SOURCE: if my battery is discharged -flat- the charger
there is always a voltage cutoff for all inverter, but it does not stop it from charging when the batery is low,accept the battery is bad
Posted on Feb 26, 2010
  • 2219 Answers
SOURCE: When connecting discharged battery to charger
The battery is dead, that is why it does not change from green to red. you need to replace the dead battery.
Posted on Apr 11, 2010
Mr Biola
  • 496 Answers
SOURCE: Samsung b3310 was charging overnight
DEAR FRIEND, YOU WILL HAVE TO REPLACE THE CHARGING I.C
Posted on Feb 03, 2011
makoy32000
  • 302 Answers
SOURCE: My phone will not charge. I can connect it to the
It maybe a problem on the phone already and not on the battery. Something inside the power ic / board that's why any battery will not hold charge for long. Try also draining the battery and then charging it for a full 2 hours with the phone powered off as this charges the phone faster.
Posted on Mar 07, 2011
  • 11 Answers
SOURCE: HP window mobile phone Model: -hw6915, Serial No.
Try charging it on the wall plug. Sometimes desktop chargers only charge 60% of the battery, and in the phone appears as 100%.
Posted on Mar 21, 2011
My tablet discharges instead of charging. Why?
check for power at the charger
many rechargeable systems will discharge the battery if left connected to the phone , tablet , laptop and the power supply switch off
Jul 14, 2017 | Tablets & eReaders
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Tablet wont charge
Apr 01, 2014 | Samsung Tablets & eReaders
I have galexy tab 3 7.0 SM_T210R when it's on standby mode charging normally but when i turn it off it doesn't charging anymore what's the problem??
Apr 01, 2014 | Samsung Galaxy Tab 3 7.0" - White...
Unable to switch on my samsung T210 tablet
Feb 17, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
How do I charge the battery of my ACER note book PC? What is the correct manner to charge it? Should I always plug the Note Book PC into the main AC when I log on to the computer?
Yes you should when the battery is low.
You can check the amount of charge in your battery by -
Open Control Panel - Power Options - click on Power meter tab - un-tick Show power levels on each battery.
Apr 14, 2011 | Acer Aspire One PC Notebook
HP DV6915nr AC charger does not turn on or charge the battery.
You have a defective regulating circuit on the mother board that will not allow charging or a broken connector pin at power connection .
Aug 13, 2009 | Computers & Internet
A35 s1592 battery won;t charge
You probably have a problem with your power adapter. Since you mentioned that the battery discharges when connected to the adapter, it means that the charger is acting as a load instead of the other way around. This is a typical behavior of a defective charger.
Try to check the output of your adaptor using any voltmeter. The voltage reading should be approximately close to the voltage rating as printed at the back of your laptop. If not, then its wiser to buy a new ac adapter instead of sending it for repair to electronic shops. Most of these chargers are no longer reliable when repaired, and might cause more problem to the laptop instead.
Nov 09, 2008 | Toshiba Satellite A35-S1592 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
