Question about Fisher and Paykel WA37T26 Top Load All-in-One Washer / Dryer
Panel cover for pause button broken need to replace panel
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 242 Answers
This happens with these machines over time if pressed too hard, you need to call F+P and get a new decal / top panel, depending on which is damaged.
Posted on Nov 11, 2013
Start/pause button is not working on my LG washing machine. All other buttons are working fine?
Problem maybe that the START/PAUSE button has broken loose from the control panel. All the buttons are attached to control panel and "hinged" so when you press the button, the button presses a small button switch on the display control. You may have to order
the Control Panel.. Disassembly is required to inspect.
It would be least likely that the Display PCB is bad..
Aug 19, 2014 | LG WM1814CW Front Load Washer
Cant get it off of the pause feature
press pause button again, wait for it to respond
(make sure door is closed)
if that doesn't work, press and hold pause button until something happens.
if that doesn't work, power off, then restart
if pause is on all the time, and never resets, even after power down/up your button is stuck/broken, fix/replace button or panel.
Jan 01, 2013 | Washing Machines
Gas dryer won't start
see the causes:
Power from the house
c.breakeer or blown fuse reset and replace
Door switch
test for open or defective, this close the relais for start the m.motor
Timer
dirty contact, loose wires, broken or burn, or defective timer repair and replace
Thermal fuse
test for open and replace see how
Jun 18, 2012 | Dryers
Start button broken
front panel will need to be taken off ..pcb assy removed ...refit new button ...replace pcb ..panel on
Jan 04, 2010 | Washing Machines
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
Sony Bravia KDL-40V300 won't turn on.
Unfortunately 5 blinks is a LCD panel error. The only way to fix it is to replace the whole LCD panel. This is the most expensive part in the TV.
part number: 1-802-488-12
List price: $1336.32
Core charge: 1790.00
You could try to replace it yourself but would need to take the whole TV apart by first taking off the back cover, then removing all the boards in order to get to the panel before putting it back together but I would just recommend buying a new TV as the price of the repair exceeds the price of a new TV of the same size.
Oct 13, 2009 | Televison & Video
Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Toner light on
Open the front cover and leave open while completing the following steps: Turn the printer off. Hold the 'go' button while turning the printer on. All panel lights should be on. Release the 'go' button. Press the 'go' button 2 times. Pause. Press the 'go' button 5 times. The toner light should be off. The paper light should be on. Close cover. The ready light should be the only light on.
Apr 18, 2007 | Brother HL-2040 Laser Printer
Fisher and Paykel WA37T26 Top Load All-in-One Washer / Dryer Logo
23 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
