Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Mouse chewed wires need to see wireing to key
  • Craftsman Master
  • 2,478 Answers
THERE A DIAGRAM IN YOUR OWNER''S MANUAL.
Posted on Oct 16, 2013
2002 Buick Century Custom. Why won't the radio turn on?
Perhaps the rodent chewed on a wire the repairman missed.
May 13, 2015 | Buick Cars & Trucks
I have a 2004 ford f-150 heritage xlt. check engine light came on and codes are po171 and po174. my book tels me its system adaptive fuel too lean (bank1and2). how should i start my problem solving?
check bank 1 and bank o2 sensor wires make sure a mouse didnt chew them up most wires are soy based and them mouses chew them and make homes in the cabin filter in stuff if not you got bad o2 sensors
Dec 02, 2012 | Ford F-150 Cars & Trucks
My husqvarna i wont suhts off when i turn key nothing happens
remove the upper cover from the engine and see f a mouse chewed threw the small wire at the coil that goes to the switch
Jun 20, 2012 | Garden
TORO 20074A Starter not working. Battery is fully charged. Nothing happens when you turn key, I've had it more than a year so I know what it should do.
OK seems to me you have a connection problem. This doesn't always mean that a connection where two wires plug together is bad. It could be a problem as simple as a mouse chewing thru a wire.
Take your time and check the wire or wires that go from your battery down to the starter.You may very quickly find your problem. A bad contact, a broken wire, a disconnected wire, or that bad little mouse, which will lead you to the purchase of a mouse trap before he causes you any additional headaches. GOOD LUCK.
Jul 02, 2011 | Electric Lawn Mower
Odometer and guages not working at all intermintently now radio has stopped as well
i had the same problem. you need to take the fuse box apart from the engine compartment to acess the wiring inside. once apart you need to check the wires. mine were looked as if a mouse had gotten inside and chewed some wires. there's lots of wires so check each one carefully.
Dec 16, 2010 | 2004 Chevrolet Avalanche
I have a wireless lazer mouse and key board, the mouse all of a sudden started acting eratic and the red lazer light had gone off. I tried troble shotting but it came back an said that everthing was...
common causes; -dirty optics, clean red light area with canned air. -polished or shiny desk surface. optical mice dont like shinny surfaces. try a piece of paper under the mouse to see you need a mouse pad. - batteries low. even though they have some charge, low batteries can cause erratic behavior. as the mouse and base connect then fail, then connect, then fail. ect. often people dont realize how fast optical mice eat up batteries. check the wire to the base, sometimes these get caught in sliding keyboard drawers and get damaged. hard to see untill you inspect the whole wire( to the base anyway). Animals sometimes chew em up too. :) if any of the above help you. please provide some thumbs up. Cheers
Aug 26, 2010 | Logitech 9311570403 Mouse
The wiring for the injectors was mouse chewed. We
The end pieces are commonly refered too as pig tails.
Mar 29, 2010 | 1993 Dodge Spirit
Started fine twice in matter of 2 min. Failed to start afterwards, Recharged the Battery 2 or 3 times, Checked Air Box. Removed Large Mouse Nest. Still will not "Fire" ! Otherwise I have never had ANY...
I have had cars in that the mouses have eaten some parts of wiring. Hard to find all the problems. First check if battery cable to starter and groung are solid. Inspect every where under the engine for chewed wires. If some wires are chewed , when starting they get hot and will not allow full voltage to go thru them
Oct 14, 2009 | 1991 Plymouth Grand Voyager
Mouse chewed on right side center coil replaced coil and connector, but still wontfire on right bank
Sounds like the trigger to activate the on/off function of the coil is missing.Having power at the coil is good but to activate the coils build up/collapse you have to have a signal to tell it when to.You will have to back probe the trigger wire to find out where its been chewed with a continuity tester with noise.The noise option,multi meters,is very good if your doing a bit of testing on your own and tells you that cicuit is intact with out having to read multi meter screen.Good luck with it
Oct 31, 2008 | 2002 Jaguar S-Type
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
