Question about Sky Enterprise USA Audio Players & Recorders
How do I get a copy of manual for Living Fresh 3500 SQF Ozone Ionizer? What do I do if I see sparks above plates?
SOURCE: Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Posted on Jun 06, 2008
Saigua
  • 981 Answers
SOURCE: Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Posted on Jun 23, 2008
namizhka
  • 148 Answers
SOURCE: Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Posted on Sep 25, 2008
SOURCE: No Ozone
HI,I HAVE A LIVING AIR XL-15 S,SERVICE REQUIRED LIGHT IS ON,UNIT IS CLEAN ,BUT NO OZONE.THANKS
Posted on Nov 30, 2008
  • 80 Answers
SOURCE: I have an Alpine Living Air XL15 which doesn't
The plates should not glow, but on High, you should hear a buzzing sound. But, you should also smell the ozone. I've only worked on two, but the reason they both didn't work was that the connectors on the wires leading to the plates were corroded beyond use. The top connector was the worst. Cutting them off and installing new ones solved the problem. Also, when you clean it, always clean the contacts where they touch the plates with alcohol. Look at the plates to see if they have more than one spot of glue around the center of the plate. (both sides) If so, they will be less noisy than older ones. Hint - Replace the plates when the glue on them turns dark brown.
Posted on Apr 04, 2009
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
New Lasko Tower Fan smells when we have it on the ionizer option? Is this smell toxic?
Ionizers generate ozone, that is the same smell that you would have near an electric motor or a copy machine. The smell is caused by electric sparks that occur during the ionization process. Essentially high voltage is applied to a grid, air passes over this grid and electrons jump off of it and into the air. They then attach to any particles that are present in the air and make those particles attractive to anything less charged than they are.
There is a limit to how much ozone an air ionizer is allowed to produce because ozone is a respiratory irritant and is not desirable to have in large amounts. Ozone also damages rubber. A commercial air purifier has to certify that it is in compliance with that law in order to be sold. The difference is that they can change characteristic based on how clean the grid is and how much humidity is present.
Jul 01, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Is this invrioionizer safe for people with heart or lung disease
Those devices use a process call IONIZATION to clean the air. What this does is make high voltage that jumps out into the air and attaches to particles in the air. Those particles are now attracted to anything with an opposite charge. In some machines there is a plate that has the opposite charge and a fan that pulls the air into the machine. When particles that are charged come into the machine, they are drawn to that plate and stick. The plate gets dirty pretty fast and has to be cleaned. The problem comes when the ionizer begins to spark. This creates ozone and ozone is harmful to people and animals, rubber and many other things. I looked up the name of the machine that you listed and the closest I can find is a really old reference to a radio shack device. the Environizer™ (630-0612/630-0613) This device was made just after regulation by the federal government that says 50 parts per billion is the limit so that device SHOULD be ok. However it has to be maintained and cared for. There is a great article here:http://www.allergyclean.com/problems-with-ozone-generators-and-ionizers-that-produce-ozone/
Just keep in mind the difference between ozone generators and air ionizers, they are not the same thing. If you need more info let me know.
Mar 11, 2016 | Air Air Purifiers
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
89 people viewed this question
Top Sky Enterprise USA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sky Enterprise USA Audio Player and Recorder Expert? Answer questions, earn points and help others
