Question about Nooka ZOT V - White Face - White Strap Wrist Watch
I just replaced the battery in my Nooka Zub Zen-V, now the display just flashes nonstop. I have tried pressing all four buttons for up to 30 sec. and the entire display turns on but when i release any of the buttons it just goes back to flashing.
  • Nooka Master
  • 18,402 Answers
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.Shortcut battery with AC contact. AC can be found on the sides of watchI just replaced the battery in my Nooka Zub Zen-V, - lb_icon1.png movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs...
Posted on Oct 16, 2013
  • Eric Stockman
    Eric Stockman Oct 16, 2013
    How do i find the AC contact? this isnt a mechanical watch, so there is no movement
  • Les Dickinson
    Les Dickinson Oct 16, 2013
    If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic. There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery. I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery.If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic. There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery. I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery.
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: the nooka zub keeps beeping
Follow this link and download manual: http://www.nooka.com/instruction-manuals-wp-1562.html Read how to set alarm.
Posted on Feb 26, 2011
escapement
  • 2334 Answers
SOURCE: I've just recieves my nooka
http://www.nooka.com/instruction-manuals-wp-1562.html Follow instructions after manual download.
What type of battery does the nooka zub zirc watch have?
Take your watch to a jeweler who will open it up and identify the battery type. Might be a good opportunity for battery replacement.
Mar 14, 2017 | Nooka Watches
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
hi,
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
http://www.nike.com/timing/extranet/product/os_alticomp/osac_manual_eng.pdf
If it doesn't help then try another new battrey.
OK
Sep 19, 2011 | Nike Lance Armstrong Limited Edition Lance...
My nooka watch constantly blinks and makes beep sounds. how do i stop this? and why it is beeping?
Hi there! A Nooka watch flashes and beeps when the battery is almost at its end. The battery required is a CR2016. You should be able to get the battery replaced at any local watch repair or jeweler!
-Nooka
Sep 10, 2011 | Nooka ZOT V - White Face - White Strap...
Beeps all the time and the screen keeps on blinking. i cannot reset it. i tried presing all the buttons but it doesnt work.
I had the exact same problem with my watch, it wouldn't stop beeping or flashing and the reset would not work. I fixed the problem an hour ago by replacing the battery in the watch.
hope this helps!!
Mar 27, 2011 | Nooka Unisex ZUB Polyurethane Watch...
I need calibrate Tissot t-touch
Syncronisation sequence is in the user manual. syncronisation is as follows.. 1) Press T to activate touch system. 2)touch the screen centre to show units display. 3)hold T button for approx 5 secs till the hands point to 12o clock. 4)use the + & - buttons to control the minute and hour hands... you must syncronise them both to 12 oclock exactly. 5)when you have them both pointing to 12 exactly, press the T button to finish the sync. the hands will now go back to the time. If the hands often go out of sync, the battery is probably worn and will at some stage the 'bat' warning will appear. (this initially only flashes every 20 secs, so watch the display for over 20 secs to see the 'bat' warning. eventyually this becomes permanant display). Batteries normally last about 6 years
Jun 04, 2009 | Tissot T-Touch T33759851
Changing the time on my wristwatch
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Mar 08, 2009 | Armitron Two Tone Sports Watch
Nooka ZOT V - White Face - White Strap Wrist Watch Logo
217 people viewed this question
Top Nooka Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Nooka Watch Expert? Answer questions, earn points and help others
