Question about Tablets & eReaders
Gem10313bk hanging on start-up. Need restore instructions
I don't know my password to Ipad need to hard reset
Can only be done via a computer that has iTunes on it. Log in with Apple ID, back up the device and then Reset.
If you know the password it can be reset via Settings.
Mar 23, 2017 | Tablets & eReaders
Tip
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
I need help with the passcode for my ipad
Is there anything wrong with the passcode? If your iPad is locked and you forget the passcode, please follow the steps below to unlock it.
1.Connect your iPad to your PC or Mac.
2.Select your device in the iTunes sidebar, and click the"Summary" tab.
3.Click "Check for Update". iTunes will show you if there any new version of iPad software is available.
4.Click "Restore iPad". You can finish the restore process by following the instructions given. During the process, a recommend that tells you to back up your files will be given. You can restore your data after the process is complete.
Now, you must have restored your iPad.
Note: Even you bring your iPad to the Apple service center, Apple staff also need to restore your iPad to unlock it. That's to say, you need to erase everything on it.
http://www.leawo.org/tutorial/forgot-ipad-screen-lock-password-how-to-recover-data-from-locked-ipad.html
Nov 08, 2016 | Apple iPad Tablets & eReaders
How can I restore to factory settings?
restore to factory Patricia, Easy to follow instruction, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kindle Touch How to Reset to Default Settings H2TechVideos
How to factory reset Kindle Paperwhite or Kindle Touch for sale
http://glyde.com/glydecast/how-to/wipe-kindle
How to Reset Kindle
Apr 11, 2016 | Amazon Kindle Touch Screen Wi-fi 3g W/...
Its not a phone its aipad16gb rated 5.1v-2.1a class b. just bought it and cannot get into it because it needs a 4 digit passcode and i dont know it just bought it at a yard sale
hi if it's ipad you need download and install Itunes to your pc/laptop Apple United Kingdom iTunes Download iTunes Now then connect ipad to pc, run ITunes and it should detect your tablet you will see it in the right upper corner. Click on it and you will be taken to the summary tab where you will see restore button. click on it and follow the instructions and your ipad will be restored.
Apr 06, 2014 | Apple Ipad A1219 16gb Wi-fi
Tablet wont charge
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Apr 01, 2014 | Samsung Tablets & eReaders
I HAVE A TBS "T-PAD" THAT I NEED "DETAILED" INSTRUCTIONS ON HOW TO FACTORY RESET OR HARD RESET. I HAVE NO MONEY TO TAKE IT TO A REPAIR SHOP , HELP ME!!!
you should be able to go into you settings and find the factory reset there and before reseting it check to see if there is a back up and restore box if there is click it so when you turn the tablet back on you should be able to restore all of your apps and music content back.
Nov 11, 2013 | Tablets & eReaders
Hcl me tablet y2 hang on logo
help with the hang on logo on my hcl y2 tab....
May 29, 2013 | Tablets & eReaders
Ipad is lockd and i have forgotton password
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present.http://support.apple.com/kb/HT1212
For restore instructions, see this: http://support.apple.com/kb/HT1414
Aug 31, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
181 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
