Question about Acer TravelMate 330T PC Notebook
Replace cmos battery
How to open Acer TravelMate 330T PC to replace the cmos battery
    Sniper:
  • 52 Answers
Hi, you can follow this steps: Just Go to Pag. 67, or you could just use this Time Sync Tool, you are only interested on have the time and date correct every time you use your computer.
Posted on Oct 16, 2013
leecom72
  • 4806 Answers
SOURCE: Acer travelmate 4650, after bios flashing, no display.thanks.
HI there
Sounds like the bios flash has failed, the only thing you can do now is try to flash again, make sure you have the right bios update for that model machine, suggest you get a USB floppy drive so you are able to re-flash the bios, if it still doesn't work then the machine is rendered useless.
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
  • 338 Answers
SOURCE: I can't find the cmos battery in my Acer TravelMate 512DX
you have got an older model, try this:
follow the instructions:
you will need:
a slim x-screw-driver
a sharp knife with a slim blade and
a cup or else for the screws, don't loose them!
a new c-mos bios battery model: CR-1220 (exchange it while your in there!)
you find c-mos battery and hdd under the keyboard!
- turn off the power, remove accu and charger cable, for static electricity is friendly fire
to your laptop now !
- open your screen to max. fold (angle of 180 degrees)
- look for removable plastic part near to left holder of screen
- carefully remove it
- also remove plastic panel right to it in the section between display holders
metal should be visible now
- carefully! remove keyboard, starting at the left side, continuing topside
as you won't be able to fully remove it, simply turn it over
- unscrew any screws holding the metal plate, remove it
- now you see: left the CPU plus cooler, top right middle the hdd still in an adapter attached
to the mainboard, at it's lower right the C-MOS battery (g
- turn loos these screws
- carefully remove the frame/adaptor holding the hdd
- unscrew again the adaptor
- seperate hd fram adaptor
... and gotcha!
be careful to get a proper notebook hd (samsung or such)
exchange CMOS-battery by chance
reattach new hd to frame, again carefully!
to reassamble: rewind the procedures
put everything back in place
replug, pray and turn on the lappie.
wish you luck.....
Posted on Jun 13, 2009
Testimonial: "Thanks for all of the information. The keyboard was destroyd during the removal process so we bought a new one instead."
babes_ganda0
  • 381 Answers
SOURCE: cmos battery location
open the top key board then under this key board you located the cmos battery and jumper settings..good luck
Posted on Jun 26, 2009
  • 14 Answers
SOURCE: How to replace a cmos battery in an acer
Look at the manual here...
http://www.scribd.com/doc/12027454/acer-travelmate-2300-4000-4500-service-guide-factory-repair-manual-maintenance-sgtm2300tm4000tm4500
RTC battery is what you're looking for....
Posted on Oct 27, 2009
  • 4090 Answers
SOURCE: cmos battery acer travelmate 4200
most times the battery is located under the ram chips
there is also 2 pins that can be shorted together that will reset the bios password if you cannot see the battery when opening the ram door.
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Replace CMOS battery
YOU CAN DO IT IN A SERVICE CENTRE.........................................................................................................................................................
Mar 22, 2014 | Acer TravelMate 3202XMi (LXT4806071) PC...
How to Disable Acer Travelmate 240 BIOS Password?
To disable the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and the bios password will be disable.
Take care.
Nov 19, 2010 | Acer TravelMate 240 Notebook
Cmos battery acer travelmate 4200
May 07, 2010 | Acer TravelMate 4200 Notebook
How to remove keyboard to change cmos battery for Acer TravelMate 529ATX PC
I have an Acer travelmate 529ATXV and need to change the CMOS battery. I think it is under the keyboard but I am not sure how to remove the keyboard. Any help would be appreciated.
Mar 08, 2010 | Acer TravelMate 529ATX Notebook
How to replace a cmos battery in an acer travelmate 4000
Oct 27, 2009 | Acer TravelMate 2300 Notebook
Cmos battery location
Jun 26, 2009 | Acer TravelMate 2300 Notebook
How to resert a cmos password
First of all as you have forgotten the password to reset the password you have to open the notebook and remove the CMOS Battery for a while and then replace it restart the notebook after you restart the notebook all the default setting will be loaded in the cmos setup you can enter the cmos setup and set the password again.
Jun 04, 2009 | Acer TravelMate 2300 Notebook
Acer TravelMate 330T CMOS Battery Replacement
If you look closely there is a tiny button release right on the frontier. here some pix
Nov 25, 2007 | Compaq Presario Notebook
Acer TravelMate 330T PC Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
