Question about Technics SL-1210M5G Turntable
Left channel not producing any sound, right side works perfectly
  • Technics Master
  • 5,056 Answers
Disconnect the wires to the cartridge. With the amp on. Touch each wire (one at a time) with your finger. Two of the wires should buzz (1 left, 1 right) if the left doesn't buzz either the connections are faulty or the pre-amp in your amp is.
If you get a buzz on the left, replace the cartridge.
Posted on Nov 16, 2013
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: No Sound out of Left side
is it possible to swap the left and right wires on the needle cartridge? does the sound change sides? if yes bad cartridge if you still only get sound from right side try changing around the rca phono plugs
Posted on Jan 04, 2008
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
Can anyone tell me if the Adcom 5503 three channel amp is common ground? I want to use it to power some old school polk SDA 1C as my mains and a CSi5 polk center. Thanks
no reason why not, 3 channel amps used to be the "state of the art" back in the early stereo days. the third channel was produced from the sum of the right and left channels, (the plus side of the right and the plus side of the left were sent to the center channel. produced what was considered at the time a true reproduction of the sound as it was intended to be. your lucky to have this old amp.
Mar 12, 2011 | Adcom GFA-5503 3-Channel Amplifier
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
TX-SR603X Left channel Front & Surround not working in all modes. Issue follows the receiver when switching speakers. Mono only produces sound from the right side.
Sounds like the left channel front etc, transistors or whatever powers it have failed. They will be on a heat sink, you just need to identify them and replace them.
Nov 28, 2009 | Audio Players & Recorders
On my Mag Innovision model 700 P lcd monitor, the integrated right side speaker does not produce any sound. In XP control panel I do have both left & right speaker set to max.
On the plug to the computer sound card, is the plug completely inserted? The end of the jack is for Left channel and the right channel is only fed if the plug is fully inserted.
Nov 08, 2009 | Mag Innovision InnoVision DX 700T Monitor
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
Speakers on the right side of my AVR will produce no sound in any
change the right channel audio ic of your denon amplifier.
Jan 07, 2009 | Denon AVR-1906 Receiver
Old Turntable Philips
You may have a bad stylus (needle), it can cause just that type of problem. Find a service center near you and see if they can get a replacement for you. They are very easy to replace, but very difficult to find.
Hope this helps.
Dave
Jun 30, 2008 | Audio Players & Recorders
Jan 04, 2008 | Technics SL-BD22 Turntable
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Technics SL-1210M5G Turntable Logo
67 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
