Question about Sangean ATS 808A AM/FM/SW Radio
Dc011 wont stay on station and tune knob is not accurate when turning
I have a bluetooth sony cd player and my radio stations wont stay tuned in
You are loosing the Bluetooth connection when the car is shut down so you then loose the stations.
Sep 28, 2016 | Sony Car Audio & Video
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Tunner circuit board
5140019-42 Tuning knob assy is the most common - it can also be the PCB but if the radio works but you can't change the station I would replace the tuning knob assy
Jan 26, 2013 | Dewalt DC011 7.2-18V Cordless Worksite...
My pioneer radio wont stay tuned in
You need a 12 volt battery connection at the stereo.
Aug 11, 2012 | Pioneer Deh-1420ub Car Stereo Cd Mp3 Wma...
Radio worked fine......then I was trying to find another channel by turning the tuner knob and all of a sudden it just locked and when I turn the tuner knob it won't change stations. Nothing works but the...
This may help: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
Feb 08, 2011 | Dewalt DC011 AM/FM Radio
Did not recieved operators manual with dewalt dc011 construction radio. need to know how to set the select channels. 1-2-3-4
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
Oct 21, 2010 | Dewalt DC011 AM/FM Radio
The radio stations will not stay set when I turn radio off/on. Keeps going back to 87.5 on all memory buttons.
Hi. There is likely an internal battery within the device that has run flat over time. Changing this should cure the problem.
Feb 07, 2010 | Dewalt DC011 AM/FM Radio
No functions working , tuning nob turns but the station dos not change,stuck on fm no sound
Many of these radios have memory backup batteries and when they become weak or dead the microprocessor becomes wacky.
Feb 04, 2010 | Dewalt DC011 AM/FM Radio
The tuner knob will not tune to specific stations and is eratic when turned not being able to pick a station needed.
If you use your radio at work it could be exposed to dirt and dust and more! Could just need a good cleaning, drywall dust is terrible on electronics!
Jan 22, 2010 | Dewalt DC011 AM/FM Radio
Tuner
This sounds major.....
The signal detection used in both radios and TV sets is via special voltage sensitive diodes which alter capacity as the voltage across the diode changes.
You actually change the voltage across the diodes as you move the tuning dial.
In your case the diode only sees one voltage and is locked to a certain station, because you are not altering the capacity to re-tune to another station...
So it appears that you have lost the ability to alter the DC voltage across the diode...
The design of the tuning knob may be where this fault lies, where the physical action of turning the tuning knob does not transfer the mechanical action to the item that changes the DC voltage to the diode....maybe you have systen that uses a long cord would around pulleys that gives you nice control over the tuning maybe its just a broken tuning cord...
Maybe the tuning is done by just a simple variable resistor I'm not familiar with this system but I have given you the bascics to start on...Unplug the cord from the AC wall socket then remove the top of the cabinet and have a look to see what moves when you turn the tuning knob it will soon become apparent if there is nothing moving when you turn the knob and thus lead you on to the problem....
Maybe the knob is just loose on its drive shaft...
Cheers From YUBEUT
Nov 22, 2007 | Sharper Image SA253 CD Shelf System
Sangean ATS 808A AM/FM/SW Radio Logo
49 people viewed this question
Top Sangean Audio Players & Recorders Experts
Mark Schmit
Mark Schmit
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
