Question about Celestron 44345 Microscope
Hi , when i turn on my microscope it only displays Celestron logo and that's all. is there any way i can fix this ? thanks.
Good afternoon. I bought a Deluxe Digital
Hello, Have you tried putting something under the microscope and then trying to focus on it?Maybe the lens is out of focus. See if there's nothing obstructing the lens. If problem persists after trying those two things you should probably send it to warranty as there most likely is a bad connection between the lcd and the camera.
Hope you can fix it easily.Best regards Vlad
Dec 01, 2011 | Celestron 44345 Microscope
I got a microscope attachment from Celestron but I don't have the drivers to have it work with my computer. Can you help' Jim yamber
You didn't indicate the model, but here you will find the downloads for Celestron.
Good luck. Happy to help.
Jan 18, 2011 | Computers & Internet
My stage is no longer moving with the knobs.
With one hand push the stage down, and with the other turn the coarse adjustment down. It's a cog alignment issue. The coarse adjustment cog should be turning in order to catch the stage track.
Feb 19, 2010 | Celestron 44320 Trinocular Microscope
Considering purchase but worried about the software
This microscope does not run on vista(has a gliche in os it self) however it does work on xp sp2 and below as far as the resolution if you have enough memory no problem if not it will make your computer run slow while the program is running easy to use my 8year old son can run it and pretty much figured it out on his own even taught me a few things cause I was to lazy to read instructions.
Nov 08, 2008 | Prime Entertainment QX-5 Microscope
Celestron 44345 Microscope Logo
527 people viewed this question
Top Celestron Science & Laboratory Experts
William McMath
ray gallant
Are you a Celestron Science and Laboratory Expert? Answer questions, earn points and help others
