Question about QNAP TS212 2Bay NAS
Factory default qnap ts-212 - QNAP TS212 2Bay NAS
Why does my Kenwood TS 790 E when pressing call button causes C2 fault on display?
http://www.iw2nmx.it/Kenwood%20-%20Trio/TS-790%20Instruction%20and%20Service%20Manuals%20plus%20mods/TS-790%20Instruction%20Manual.pdf
Jul 14, 2014 | Kenwood Radio Communications
How do i do a factory reset on my mitsubishi ts-50811 tv
should find your answer in the setup menu, with factory reset
Jun 28, 2014 | Mitsubishi TS-50811 50 in. Rear Projection...
Fate 4: the cursed king QnA
The difference is shield is anterior to the heart creating space between the M-State and that previously mentioned.
Feb 24, 2013 | QNAP Computers & Internet
What is the security code qmobile e990
plz give me info security code from e990?
Oct 11, 2012 | QNAP QMobile
How do I change the language back to english on kodak easyshare C183
Press the MENU button. Use cursor-left/right to select the Setup tab. Use cursor-up/down to select the sixth item.
Here's the page from the user guide:
http://resources.kodak.com/support/shtml/en/manuals/urg01133/urg01133c5s1.shtml
Jul 06, 2011 | Kodak Cameras
Getting write-protect error on qnap ts110 folder
right click on the folder select properties thwn click the sharing tab make sure the folder is sharing and the box is not ticked make this folder private in xp
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
Remember do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 03, 2011 | QNAP Systems TS-110 QNAP Turbo NAS, USB...
Hi, I have a Cyclades TS-1000 and I do not have the root password. Is there a way to reset it to the factory defaults.
Well, you don't even have to go to that extreme to recover your root password. Connect to the console port of the TS to your laptop or workstation. Type reboot (as root) and hit Enter. As you watch the boot sequence, pay close attention as you'll need to input characters. Specifically, when you see "Linux PPC Load", press the space bar a couple of times and type out the word single and hit Enter. If you did it in time, you should see a hash (#) prompt without requesting a password. From here, type the command passwd and hit Enter. Choose your password and confirm it. Don't forget to perform a signal_ras hup followed by saveconf to ensure your changes are activated immediately and are saved to flash memory (non-volatile state). From here type reboot again and you should be back in business.
Regards,
John
Dec 05, 2008 | Cyclades TS 1000 Terminal Server
Reset to factory defau;ts
Small print in the manual says to hold down the 100/P.Scan button on the remote to toggle between progressive and interlaced. This was after I blindly tried to follow the setup screens in the manual and found that the manual doesn't match the exact screens (must be a firmware difference?) in the manual.
Also found that the factory default instructions in the manual do not include a yes/no confirmation screen.
May 26, 2008 | GoVideo DV2150 DVD VCR
QNAP TS212 2Bay NAS Logo
Top QNAP Computers & Internet Experts
David Payne
David Payne
Are you a QNAP Computer and Internet Expert? Answer questions, earn points and help others
