Question about Dryers
The high and low temperature buttons on my White Knight sensordry tumbledryer pushed in because a screw had become loose inside. Have dismantled it but can't work out how to reassemble - there is a little wire piece that fits between buttons and electrics. Which way does it fit please?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Tiugh one. Next time take a photo of the site before you try to take it apart. Or have someone send you a parts break out of the machine. Good luck.
Posted on Oct 18, 2013
3 Suggested Answers
beltronic205
  • 1474 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
SOURCE: My White Knight sensordry tumbledryer has been
sounds like the bearing carrier has come away from the drum-same as mine,seems to part of the drum
so not available seperately-its riveted on not bolted,mine has deformed and enlarged the rivet holes in the drum so a repair dosent seem practicle if yours hasnt chewed itself up then you may be able to replace the rivets with nuts and bolts and maybe change the bushing kit for about 6 quid
Posted on Dec 30, 2010
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
I had a white rodgers thermosat system & its digital. I dont what model # it is but I want to know should I have the temperature set low or high if its 80 degrees in the house?
The set temperature is the temperature you want the system to cool the inside of the house.
A lot of digital thermostat will display the current ambient temperature. When you push the set temperature up or down buttons the thermostat will display the set temperature momentarily and will change if you push the up or down button.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
White knight tumble dryer wont switch on (44a)model push the switch no click
hello check inside the door to see if the long pin hasn't snaped off this connects to the interlock that activates the motor if this is ok check the capacitor next to the motor this gives the motor a boost at switch on hope it helps
regards
shaun
Mar 12, 2011 | Abbaka White Knight 44AW Electric Dryer
I have a white knight WK447 with 2 buttons on the front. Which one do you push in to dry quickly please?
here is a website to download information on your dryer, Good Luck Tim:
http://search-pdf-books.com/white-knight-wk447-tumble-dryer-pdf/
Jan 16, 2011 | Dryers
My White Knight sensordry tumbledryer has been making a loud banging noise, (like there are shoes banging about). Is it a bearing problem? Is it a problem that i can fix?
Jan 31, 2010 | GE Profile DPSB619ED Electric Dryer
Oct 01, 2009 | Dryers
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Aug 01, 2009 | Villeroy & Boch Home
Dryers Logo
67 people viewed this question
Top Dryers Experts
