Question about Sony KLV19T400A 19 in TV
Sony bravia klv-19t400a 4 times blinking - Sony KLV19T400A 19 in TV
SOURCE: I have a sony bravia KLV-40U100M with no power
tv smoked and will not power on
Posted on Jul 05, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
welcomejee
  • 10594 Answers
SOURCE: 8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Posted on Feb 09, 2010
  • 35 Answers
SOURCE: There is no picture and no sound on my sony bravia
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
Posted on Apr 11, 2010
techman007
  • 1112 Answers
SOURCE: The picture on the screen
HI:
This is due to a faulty digital board, your board has failed replacement is the only option.
Posted on Jan 24, 2011
Sony bravia klv 24ex430 red light blinking 2 times?
KLV-24 EX430
RM-GA022
Troubleshooting
3-3. Standby Led Blinking
3-3-1. 2-times Led blinking
2 times Blinking
Check DC voltage at
JL6023
Is it 18V 19 5V?
Yes Change
- 19.5V? B*board
No
Take out adaptor
and test at adaptor Yes
output is it 18V - 19.5V?
Change
B*board
No
Change
adaptor this is flow chart for 2 blink
Aug 13, 2017 | Sony Televison & Video
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
Sony Bravia KLV 19T400A Dead
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 17, 2014 | Sony BRAVIA Televison & Video
Please provide SONY BRAVIA KLV 46X200A red standby led blinking error code meanings
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 04, 2014 | Televison & Video
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
3 blinks sony bravia klv 32v300a
3 blinks ussally is an indication of a loose lamp door
Jan 10, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia KLV-V40A10 When turning the tv on the on switch flashes 7 times then turns the TV off. Thanks
sony bravia klv v40 schakelt op willekeurige sijden ove rop slaapstand. lampje knippert dan 8x en vervolgens 4 sec. puaze en op nieuw knipperen.
Aug 07, 2010 | Sony Televison & Video
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KLV19T400A 19 in TV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
