Question about Sewing Machines
My minghui is sawing just top and bottom is just mess can u help me???
    Sergeant:
  • 216 Answers
Thanks for the question.
If your machine is not sewing on the bottom or making stacks of thread called (bird nesting) there are several simple fixes for this and some not so simple.
First you need to make sure that you are threading the bobbin into the holder correctly, Insure that you pull the end of the thread through the little slit on the side of the bobbin and that the thread is somewhat snug but not hard to pull.
Once you have done this replace the bobbin in the bobbin holder and thread the feed thread over the top from the spool or thread. making sure that you run it through the auto tensioner.
Set the auto thread tension to +1 to start, go ahead and thread the main feed through the bobbin feed so that you have both strings on the sewing deck.
Now with a piece of used material, pull both bobbin feed and Main thread behind the machine, insert your test material, drop the material tension foot onto material and start to sew a 1 inch spot.
After about one inch check to see if your machine is still nesting thread, if it is you need to add more tention to the main thread by moving the auto tensioner to +2. Now test sew again a short distance and recheck. If you still have a issue move the tension up until the nesting of string stops.
If you reach the stop. than it\'s likely that the bobbin holder needs to be adjusted.
The bobbin holder has two small screws in it generally that allow a very small screwdriver to adjust the bi metal pensioner on the bobbin holder. This is the area where you slide the string through the little slot in the bobbin holder.
You can tighten those screws until the string is harder to pull out of the bobbin holder. You may have to repeat this step several times until you get the tensions just right.
but make sure that you reset the main Thread tension to 0 before you start adjusting the bobbin tension.
If after all this work fails you may have to replace the bobbin holder to correct this issue.
There is one other fix that you can try before replacing the bobbin holder and that is to purchase more expensive thread. The reason behind this is that the more expensive thread is thicker and causes more friction in the bobbin holder..
I hope that this has helped you, I know what it\'s like not to have a working sewing machine.
Best of luck and thanks for using Fixya.com
Posted on Oct 17, 2013
Why does my singer 2732 thread keep breaking?
This happened to me several times. The way I fixed it was to:
- clean underneath where the bottom spool goes in, usually there is where the dust keep collecting.
- when holding the case spool before inserting it in the machine, make sure the thread that comes out is rolling towards YOU, the normal rolling way and NOT backwards.
- make sure the thread is not loose on the spool due to not enough thread on it.
- you might also want to check the thread on top - going through all the "curves", that somewhere is not being stock, that the thread is NOT skipping any"corners" and do not do any shortcuts when threading.
- there has to be ENOUGH thread on the TOP spool and on the BOTTOM spool.
- lastly, - pull everything out and start fresh with all the threading - top and bottom after cleaning the dust out and maybe any little bits of cut thread left over from the past work.
I'm sorry but that's all I can thing off .... I have been sawing for over 50 years and this is the way I always fix my machine every time, either manual or electric.
One thing is for sure, not all threads are appropriate for sawing machines and if you are trying to saw elastic, then you have to use the correct dial, because the usual one will NOT work and it WILL brake the thread !
I hope any of the above will help ... :)
Aug 31, 2014 | Singer Sewing Machines
The lock for holding needle of my minghui sewing machine need to be replaced where can i get it
Hello
Contact your local reputable sewing machine retailer for a correct replacement.
Happy Sewing.
Jun 07, 2014 | Husqvarna Viking 1
Stitch issues
Find the tensions on your machine. Usually a screw below on the bobbin regulates the top stitches tension. Usually a numbered wheel on top--where the thread is around it--regulates the bottom stitches. YOU NEED TO ADJUST THE TOP WHEEL, test on scrap material, and if looser, you are in the right direction. If it is still a mess. turn the knob to a lower number.
Apr 04, 2014 | Brother CS6000i Computerized Sewing...
Minghui sewing how much length the needle has to
my overlock sewing is not working properly the thread broke in the 2 needles , any solution
Oct 11, 2013 | Toyota TL-432DE Mechanical Sewing Machine
My minghui sewing machine is not sewing stitches
have it serviced. they should be serviced on a regular (yearly) basis. just sitting is not good for them.
Nov 28, 2012 | Sewing Machines
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
Upper thread balls up on the bottom. Makes a matt on the underside of garment.
If your thread messes up on the bottom then the problem lie in the top threadinbg of the machine.. Some how it is not thru the tension wheel like it needs to be. FYI.. Loops on the bottom fix the top.. Loops on the top, fix the bobbin.
Apr 19, 2009 | Singer Sewing Machines
Im pretty sure i have my singer 5525 threaded right but i think the bobbin is wrong but when i try to sew the top looks fine but the bottom is a thread mess an the thread keeps breaking My sewing is a...
Hopefully you have a new needle in the right way and not a dull bent one. And are putting your bobbin in correctly so that when looking at the back of the bobbicase and when pulling the thread it turns clockwise. Counter-clockwise things like this will happen. Also that the foot is up when threading ensuring that the thread goes between the tension disks. Serious jam ups can also cause it to get out of timing which you may need a tech for.
Nov 13, 2008 | Sewing Machines
angle the bottom might be a mess but it is the top thread that
you see balled up .Pull the top thread and make sure there is tension on it ,if not check the thread is between the discs and there is nothing else between them .if this is ok there is something stopping the top thread from being pulled back up
through the needle plate to form a good stitch,if you can turn by hand and watch where it is catching you might be able to solve it.
Aug 17, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
150 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
