Question about Cell Phones
Smart roaming problem
Sim card registration failed
  • 206 Answers
There can be a few reasons behind this problem :- sim card slot problem- if the sim card is not getting connected with the phone. :- sim card problem(mostly with used or a bit damaged cards)- the sim card is not getting connected with the phone again. :- cancelation of services by the service provider. solutions/ diagnosis:- try other sim card in the same phone, if it works then the sim slot is perfect, contact the customer support for your service provider to check on cancelation of services. . If services are active then check the phone with a service center
Posted on Oct 16, 2013
  • 30 Answers
Consult you your telco about roaming. the country youre in for roaming probably not support your telco or simply having technical difficulty at the moment
  • 237 Answers
SOURCE: sim card reg failed in my 6630
confirm that your phone is not locked to a particular network carrier especially if you desire to change sim card operator.
if this were so, you will need to unlock your handset first before re-inserting your sim card into your handset.
third way out is to flash your phone.
Posted on Nov 25, 2008
  • 106 Answers
SOURCE: SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
Posted on May 08, 2009
  • 83 Answers
SOURCE: SIM card registration failed, whats wrong?
The first thing to try is put the SIM into another handset - if you get the same error message on that, the SIM is blocked. If it works in another phone, the most likely explanation is that the IMEI of your phone has been blocked by the network.
Posted on Jun 10, 2009
mohammed387
  • 1952 Answers
SOURCE: Nokia 2610 'Smart Chip Registration Failed'
off the phone ........ change the setting
Posted on Jun 13, 2009
ashraf achu
  • 274 Answers
SOURCE: keeps saying sim card registration failed and I got a new
just format your phone
Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up
Posted on May 12, 2010
I CANT USE MY ROAMING SMART SIM CARD WHAT WILL IDO
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jul 24, 2012 | Cell Phones
My smart roaming sim lost its signal..i dont know why but still it has a remaining balance..what should i do??
You can powercycle your phone. Turn off phone,remove the sim card,memory card, and battery. Wait for at least 5 minutes then after 5minutes,you can put back the sim card,memory card at battery. Try to check if your roaming card will again work. If this doest work you need to contact smart telecommunications and ask them to deactivate then reactivate the roaming of your sim. Because if your sim wont work,there will be no access for you to retrieve the load of your sim.
Dec 02, 2011 | Cell Phones
Before i left the philippines i activated my smart buddy on roamin...i typed in roam on and sent it to 333...i then recieved a message saying the roaming services will be activated shortly but when i got...
you can buy a pay as you go sim card from an english provider, and call your relatives from that card.in this way your cost will be cut, cuz you dont have to pay the so expensive roaming tarifs
May 11, 2011 | Cell Phones
Can you Solve my "sim card registration failed" Problem on my nokia e 6
when i insert my sim it says "sim card registration failed" this is a problem on my nokia e63
Jul 11, 2010 | Nokia E63 Cell Phone
My phone keeps saying sim card registration fail and i don't know what to do
hi...
I belive you got a new sim card.sim card registrations fails comes only when the delear from whom you purchased might havent gave your proff to the service providers. so please contact the delear from whom you got the sim card.
thanx
Jul 15, 2010 | Nokia 5310 Cellular Phone
Why is my sim registration failed?
Contact your Network Provider for the sim card there may be an error there side.
Jun 24, 2010 | SimpleTech PC CARD W/ DRIVELINK- SERVICE...
How to active smart roaming?
In the Philippines they dial *888 for smart assistance, an agent will activate your sim instantly.
Oct 22, 2009 | Apple iPhone Smartphone
May 08, 2009 | Nokia N70 Cellular Phone
N95 international help
is your sim roaming?.. if it is? then it has to work, or try to put another sim 1st to check on it.. if it's still the same. bring it to the pro's, co'z it maybe ur uem(power and audio ic ) problem . there they can resolve it, they could do like this hardware repairing your uem, or they will do the software to fix it...
Apr 20, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
118 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
