Question about Hotpoint Ovens
My hotpoint sy36 has power as the display / clock works but noting else will. no grill, no light, no fan and no oven. when i press the manual button it makes the little click/clunk noise that is should when it fires up but then nothing. please help
  • 296 Answers
Does top burners work? If not, make sure you have 220vac to unit.
If it is the oven only that doesn't work, then it may be the temperture sensor, element, or control panel. You can take the sensor out and measure resistance across it with an ohmeter...at room temp should read about 2K ohms...in ice water should read less?in hot water more?...I may be backwards here, but temps should vary..(.must disconnect from connection to stove). Element disconnected should read zero or close end-end and infinite from end to outside.If these test ok, sorry but it's the control panel card....$300+ if not obsolete. New ranges are about $500+
Posted on Oct 16, 2013
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
Posted on Mar 29, 2008
  • 4 Answers
SOURCE: hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
kachbibi1
  • 979 Answers
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Posted on Feb 11, 2009
Hotpoint oven does not work , but grill works fine. switched off and reset manually but still not warm enough.....
If the oven fan is working o/k, then you need to replace the oven elent located at the rear of the oven compartment behind a removeable cover.
Feb 01, 2011 | Hotpoint SY36 Style Line Stainless Steel...
How do i reset the clock on my Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Usually to the set the clock it's pretty simple on most ranges. However I'm not extermely familair with this specific one but I am familair with most other ones. For some reason my firewall wouldn't let me download the manual and upload it here. However here's the link that I was looking at. I've used this site before but sometimes it's hit and miss. If you find no other solution, call GE at 1-800- GE CARES. Hotpoint is made by GE so they should be able to point you in the right direction or at least their internal website so you can download a manual. Hope it helps and Happy Holidays.
http://www.devicemanuals.com/guide/Cooking/Hotpoint/Hotpoint-Cooking-SY36-Instruction-Manual-==TVRJME5EYzQ=.html
Dec 01, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36x display works but fan and element not working, connections seem ok
You need to ascertain that the components are getting a supply to them.
You will have to remove the oven from the housing, and remove the rear cover to check for supply to fan and element.
Jan 05, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint SY36 oven cuts out but fan keeps running
do you get code in display if so what is it . oven cutting out is a high temp problem probably / look for a thermo problem or sensor if digital . need a complete model # to help more if needed . hope this helped mm
Dec 04, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
