Question about Dryers
How do I take apart a WindDancer household cooling fan on a stand
  • Sue Roseman
    Sue Roseman Oct 20, 2013
    already figured it all out and it is cleaned and fixed!
  • mikadot
    mikadot Oct 20, 2013
    Way to go! :) sorry we missed your problem. Many volunteers are answering questions as fast as they can and we still can't get to all of them.
Cooling fans stay on (engaged) untill 40amp fuse is removed.
Is this a stand alone fan, ceiling fan or the fan in a aircon? Either one the problem indicates no switching circuit. The ceiling fan would be direct wired to live instead of wall switch; aircon would a faulty circuit but power for stand alone-99% of the time a faulty PowerPoint open circuits so no power would get through
Mar 05, 2013 | Air Cool Dryers
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
The mother board is hot
Possible cooling fan problem.make sure the vent ports are clear of lint,dust etc...do not use compressed air to blow out vents,,often this will blow debri directly into the hard drive use a Q-tip....cooling pads or 15 dollar cooling stands may keep it cool until you find someone to take it apart and see if the fans or fan is bad.
Jun 07, 2012 | Gigabyte GA-945GM-S2 (0818313003065)...
A/c doesnt cool while car is in stand still
Have you elec. fan motor check out, the reason it don't cool at a stand still is there is no air flowing through the radiator and a/c condensor, the fan sits in back of the radiator on the engine side.
Jun 16, 2010 | 2005 Chevrolet Cavalier
Sony KDF E60A10 60 in. My TV starts up but then the green light switches red and blinks 6 times. No picture or sound. What is the issue
6 blinks mean a thermal fuse problem. This model had a problem with the thermal fuse that does not close once it is opened. This is caused by a blockage of the fan that cools the optical block, usually from accumulated household dust. This causes the TV to overheat. The thermal fuse detects this and puts the TV into protect to prevent further damage to the TV. To fix, the fans need to be cleaned and the thermal fuse needs to be replaced. The parts are not very expensive (around 20 dollars for the fuse) but it does usually takes a while to fix because the unit needs to be taken apart to have access to the fuse and optical block fan. The GT board might have been damaged for the excessive heat but most likely a new thermal fuse will fix the issue and clean fans will prevent it from happening from the future.
Oct 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
How do I get my cool operator fan apart to clean the darned thing
hi! there,
well! no brand and model,anyway the guard fan has a quick clip lockaround the fan blade,be sure to unplug your electric fan before doing this, unlock clip lock then the fan has a quick handy lock knob at the center of the fan observed loosening knob there is direction arrow in loosening this if i'm wrong going counter clockwise,or take the direction indicated marked on top of knob.
pull out the blade and have it clean if this is a plastic or aluminum clean it with water and spounge/cleanser,avoid to distorsion on fan blade if happen this will wiggle when run again be carefull and on the second guard fan still connected to your electric fan,there is plastic lock nut release and pull out the 2nd fan guard,try to clean this with water and cleanser,the motor assembly with control and stand just wipe it out ,don't try to get wet specially the motor,let all dried up before reassemble.reverse the process to eassembly
Apr 04, 2009 | Dryers
Stand by
Standby does not turn off the computer. It reduces power consumption but does not turn the CPU off or the power supply. Because the cpu is still on the cooling fan stays on to cool it. If you want it to turn the fan off or be silent I suggest using hibernate or shutting it down completely.
Feb 01, 2009 | E-Machines (308714) Motherboard
If my lamp is out, would sound be present?
Check lamp cooling fan for dust blockage. It is located inside the back cover (10 screws) and is in a horizontal position above the lamp from the rear side. This is an air intake fan. The cooling fan you can see on the back panel is the exhaust fan that sucks out the hot air. A clue is hot or melt marks around the lamp housing.
If the lamp cooling fan is blocked you'll get red flashing diagnostics light flashing. It's trying to say clean me so I can keep the new lamp cool. Sony is silent on this in it's manuals. I'm guessing they don't care because is causes lot's of parts business!
I learned all this after replacement lamp burnt out after 1 week. My lamp cooling intake fan was found blocked and wasn't spinning. I saw the exhaust fan working and thought all was ok, not even knowing there were more fans. Some models even have another fan inside the optics blocker. I didn't take mine apart that far.
Nov 23, 2008 | Sony XL-2100U Projector Lamp for...
Motor on fan feels hot
If I were you I would turn off the fans when you are not at home. These are run by electric motors and by thier design as houshold and not industrial they do need time to cool. These are not designed to be ran 24/7.
Hope this helps Ya
Jul 05, 2008 | Dryers
Electric Fan - Black and Decker Typhoon Stand Fan
can you repeat this problem every time without a "cool-down" waiting period?
Mar 16, 2007 | Black & Decker BDSF1610 Stand (Pedestal)...
Dryers Logo
21 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
