Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
Front burner does not light. Turning gas on and the gas does not seem to have a lot of pressure.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
If the rest of the burners work correctly, then you have a clogged burner head. You can try to clear it out and if that doesn't work you will need to replace it. Here is the kit to order.
Posted on Oct 20, 2013
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Front right burner will not ignite
I'd get a briquette lighter down in there when you turn it on and try to light it manually. If it does not light, it is a gas supply problem (bad valve or control), and time to call appliance guy. If it does light, the spark path over to the burner may just be plugged with something. If you have gas + spark, but no fire, it almost has to be that the spark can't reach the gas for some reason. That usually comes from something being plugged up.
Nov 27, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
Burner problem
Hi there!
Check the incoming gas pressure.
Insufficient gas pressure will greatly affect the unit's efficiency.
Regards.
Apr 03, 2012 | Pitco Frialator 35CS Deep Fryer
Can not light gas grill - Weber 8006 Have done all suggested thing such as full tank of gas, regulator checked, check for spider webs. No gas seems to be reaching burners.
This grill is definitely worth fixing. I have had similar problems with several weber 8006 grills. It is usually something obstructing or diluting the flow of fuel. If you have a new tank and your igniter is working (you have tried using a propane hand-held lighter, I assume) then it seems that it must be either the hose/gas line or the burner tubes. I would first check the main tubes and cross tube carefully for places that are rusted through. Holes can lower the pressure in the tubes and make them difficult to light (try just turning on and lighting the front burner). I would then clean the tubes at the spider trap/air vent end, which is nearest the propane tank. The spider traps, if you have them, are little plastic cages and the edges snap together. You can use a vacuum to gently clean out the tubes. If this does not work, you can buy or borrow a similar, but working hose. As they say, "it is always the last thing you try that fixes the problem".
Jul 12, 2010 | Weber Performer Grill
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jpg328 does not light up after changing gas bottles? There is no gas coming from out the four cooktop burners. In front of the pressure regulator there seems to be gas pressure. the spark ignitors works...
After in detail troubleshouting and cleaning all gas passage of the cooktop and checking if no pessages are blocked,I myself went looking to the pressure regulator just after the gas bottles. After making some adjustment to this pressure regulator, the cooktop light up again. So problem is solved.
Jul 26, 2009 | GE 30 in. JGP328 Gas Cooktop
Neff gas hob burner won't turn off
yes it is sad to say
Aug 23, 2017 | Cooktops
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
48 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
