Question about Jenn-Air Cooktops
My Jenn-Air range top will spark but no ignition. Gas does not seem to have enough pressure on that burner
    Sergeant:
  • 216 Answers
Generally the issue with this is not that you don't have the correct pressure but the Burner top hat that displaces the gas is dirty.
Remove the metal rack to expose the burner itself. Make sure it's not been used recently to prevent a burn. Carefully lift the little burner cap off. This is the piece with all the holes in it the flames come from. They generally just sit on top. You will need a flashlight, know look in the little slits below the cap for cleaning material buildup. A tooth pick or a stiff bristle tooth brush can be used to clean these little slits.
The cleaning products used to clean stove tops tends to leave little trace amounts of surfactants that over time block these little slits and prevent the escaping gas to flow towards the ignitor preventing the burner from lighting.
Once you have this clean replace the top. Put the pan grate back on and try to relight the stove.
I am sure this should fix you issue. If it doesn't please let me know and I can give you some other tips to try.
DR Wilkins
Posted on Oct 17, 2013
Testimonial: "Not enough gas pressuure on that burner"
textonor
  • 130 Answers
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
SOURCE: ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
Posted on Jul 22, 2008
SOURCE: Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Posted on Jan 27, 2009
mgprice
  • 744 Answers
SOURCE: Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
Posted on Jun 26, 2009
The igniter on my gas cook top won't shut off.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jan 27, 2011 | Jenn-Air Cooktops
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
The ignitor will not stop sparking.
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Igniter misfire
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
My Jenn-Air jgc7536ads model will not stop clicking even after the burners ignite.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Dec 15, 2009 | Jenn-Air JGC7536ADS Gas Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Igniter keeps firing
The problem resolved on its own. I'm guessing some moisture from my cleaning was the culprit...when the moisture dried the igniter stopped sparking.
Jun 01, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Cooktops Logo
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
