Question about Sigma 18-200mm f/3.5-6.3 DC Lens for Pentax Digital SLR Cameras
I have a wonderful old sigma 79- 200 mm macro lens which i i used on a 35 mm film camera. I dont think i will ever be able to afford a digital setup with a lens like this so was wondering if i should get a dslr on which i can use this lens. Is there an affordable dslr body which can be adapted for this len??
  • 2 more comments
  • meadowvole Oct 16, 2013
    It was actually an Olympus. I really want to get a Nikon when I make the jump to dslr if possible. It is looking like they have some reasonable macro lenses for the dslr nikons.
  • kakima Oct 16, 2013
    Unfortunately Olympus is the one company that switched lens mounts when they transitioned from film to digital. And I won't try to talk you out of Nikon. I've been using Nikon cameras and lenses for forty years.
    Do you like the D5200? By the way, thanks for the advice!
    The D5200 is a nice entry-level camera. It's designed to be easy to learn. I prefer something designed to be easy to use. It's a nice introduction for someone new to SLRs, holding your hand and guiding you through things step by step. For someone experienced with SLRs (not necessarily Nikon's) and with photography in general, it can actually be a hindrance. More advanced cameras (like the Nikon D7000 and D7100) let you change settings with a press of a button and a turn of a command dial, whereas the D5200 may require you to delve two or three levels deep in the menu system.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sigma Master
  • 102,366 Answers
What lens mount do you have on the lens? In other words, with what make film camera did you use the lens? A DSLR from the same company should be able to use the lens.
Posted on Oct 16, 2013
3 Suggested Answers
  • 117 Answers
SOURCE: Chip to lens
Sigma cannot rechip your old 70-200 2.8 call sigma uk and see what thay can offer on 01707329999
Posted on Dec 13, 2008
  • 15 Answers
SOURCE: Can I buy an adapter to use the 28-200 mm Sigma
You may be able to find an adaptor, but I doubt it and you would lose many functions in any case. It could end up that the lens will not auto focus or that it would not meter properly. These adaptors are made so that specialty lenses (such as fisheye or shift lenses) can be mounted on cameras when needed. Your 28-200 would probably be cheaper to by in an EOS mount.
Posted on Nov 20, 2009
Can i use tamron 90-300 mm af macro on my minolta 404 si dynax ?
Tamron makes lenses with a variety of lens mounts. If the lens has a Minolta mount then yes, you may use it with your camera.
Sep 21, 2013 | Konica Minolta Minolta Dynax 404 Si 35 Mm...
Does my Sigma 28-105 mm Aspherical for film camera work on my Canon 5D Mark III?
If the Sigma lens mount is a Canon FD fitting then you can get an adapter FD to EF that will allow you to use the old lens in manual mode. If your camera isn't designed to take EF-s lenses then they will not fit on the camera. My EF-s lenses will not fit on my 6D.
Jul 24, 2012 | Canon Cameras
Are older Sigma Quantaray lenses that I used with a 35 mm SLR Canon Rebel 2000EOS compatible with new DSLR Canon bodies?
Yes. Bear in mind that many Canon digital SLRs have a sensor smaller than a frame of 35mm film. This results in the image being cropped, narrowing the field of view and making the lens behave as if it was of a longer focal length.
Sep 02, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Using old Sigma AF lenses with new DSLR Canon EOS
Hi Is the 28-70 a DF type if so it will work on a canon DSLR but if its the older one with the scale ring is on the outside of the lens it will need a rechip but I think thay are no longer avabile the 70-300 if is a super it will work or need a rechip if its a older one with a macro switch held on the lens with 2 screws it to old to up grade
Dec 25, 2009 | Sigma 28-70mm f/2.8 EX DG for Canon EOS
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 DL Hyperzoom macro Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts...
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
May 19, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
I'm looking at buying a Canon EOS 400d and wonder if anyont can confirm whether my lens from old Canon EOS 620 film camera body will be compatible. (Unfortunately lens in storage at moment so I can't...
The canon lens should work fine. Some of the Sigma lenses have to be converted by Sigma to work with digital. The last one I sent to them they only charged me $10 for return shipping. You can find their address online.
Jun 10, 2008 | Canon Cameras
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Cameras Logo
96 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
