Question about Timex T309TT Clock Radio
2003 saturn vue 3.0L, transmission fluid leaking badly. Changed front seal,still leaking. What is the cause of the leak,What could be the fix for this problem
2005 saturn vue clutch
The cylinder that activates the throw out bearing is inside the housing for the transmission. You have to pull it anyway.
Aug 31, 2013 | Cars & Trucks
2003 Saturn Vue with 151000 miles on it, leaking clutch fluid and won't shift.
The leaking component must be found and replaced or repaired. I dont know how a "garage" could have bled the line with a leak in the system. Take it back, get your money refunded or make them find the leak and fix it.
Aug 15, 2012 | 2003 Saturn VUE
2003 Saturn transmission
Do you have a leak? Is there red oily fluid under the car? If not then you just have a defective transmission. As to checking the level that requires a special tool. there is not dipstick.
May 16, 2012 | 2003 Saturn VUE
Leaking tranny fluid by the torque converter is this my rear seal?
It is most likely the front seal on the Tranny, or a leaking tranny pan gasket.
The rear seal on the engine would leak motor oil
Nov 30, 2010 | 2003 Saturn VUE
Where do i put transmission fluid in my 2006 Saturn Vue?
If you have no leaks dont worry about it. Just get it serviced if its time. Alot of cars are this way now. You need to be under the car to drain and fill. My BMW is this way
Nov 29, 2009 | 2006 Saturn Vue
When turning the steering wheel of my 2003 Saturn Vue, it makes a gutteral noise from the steering column. It is like a bullfrog croaking as long as the wheel is being turned and returned.
mine did the same thing. Where the steering column goes through the firewall (floor) there is a rubber seal. That seal has gotten dry. Apply a small amount of lube where the shaft goes through and turn the steering wheel. This helped eliminate my squeal.
Oct 01, 2009 | 2003 Saturn VUE
Adding transmission fluid to my 2003 saturn vue
the dipstick is located behind the front transmission mount and its held in by a 12mm bolt. you may need to remove the transmission mount to check the fluid. the color of the dipstick is yellow, make sure the car is in park and fully warmed up to operating temerature and on a level surface before checking the fluid.
May 28, 2009 | 2004 Saturn VUE
Transmission leak
the front shaft seal is bad on the transmission,pull out the transmission and replace the front seal which is about$8.00 for the seal
May 19, 2009 | 2002 Ford F250 Super Duty SuperCab
Timex T309TT Clock Radio Logo
23 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
