Question about Health & Beauty
Action flyer the seat is wobbly but post underneath is fine whats the problem please
Check bolts at the bottom of seat pull seat off turn upside have a look had the bolts fall out on others blue lock tight
Posted on Oct 19, 2013
2 Suggested Answers
SOURCE: Action Flyer Mobility Scooter
below the seat is a post that slides into the pastic part of the base ... there's a bolt that you need to remove first ...use 2 wrenches . Once the bolt is removed ...grab hold of the seat firmly and lift straight up with both hands. now that the seat is removed , the plastic part can swing back to expose the batteries . The batteries can be disconnected with the right size wrench and then you just pull up with the battery handle .
Posted on Mar 26, 2010
Severe Vibrations when driving. going 3mph + besides the wobble in steering wheel
This is very serious and I would advise not driving it AT ALL, until a cause can be identified. Although you said it's "not the front end wobble", it sure sounds like there still is something wrong in the front end and/or the alignment. It could be broken engine mounts, missing hardware/very loose control arms, steering box connections, loose steering column, transmission mounts, driveshaft bearings/mounts or even loose lug nuts on the wheels just to name a few. Please have the car safely raised on jacks and have a mechanic or knowledgeable person look underneath for broken/damaged/missing parts.
Jan 30, 2016 | 2002 Hyundai Accent
How do I stop it from wobbling?
The mounting bolts in the bottom may be loose or the flange mounting screws underneath may be loose. Also, the toilet may have been improperly seated on the bowl gasket (usually wax), allowing it to wobble. In some cases, it may be necessary to shim the bowl to fix the wobble. You must be careful to avoid overtightening the mounting bolts; otherwise you will end up with a cracked bowl.
Aug 09, 2015 | Home
I have a wobbling back end seat leon 1.9 tdi 2008 plate
wobbling from the rear end can be from worn suspension rubbers in the control arms. Normally it is from belt separation in the tyres and bulges in the side walls
I take it that it is a front wheel drive with no diff action at the rear.
another point may be that the rear brakes are grabbing ( out of round drums or warped discs) that is causing the vehicle to react as if the rear is loose.
Feb 10, 2015 | Seat Leon Cars & Trucks
How do I tighten a wobbly soft close toilet seat?
There are two(2) nuts under the outside edge of rim of bowl(bottom section)right in front of tank. use fingers to tighten, and pliers to secure. If it will not tighten, then the posts molded in are loose, requiring replacement. Sometimes even if new on these types.
Aug 27, 2014 | Home
I need a rear axle diagram for 1982 western flyer grand trophy
You have this posted in the wrong product category (car and truc), please select the correct one and re-post the question. Thanks
Apr 03, 2012 | Cars & Trucks
There are no instructions
If you are looking for instructions on how to mount the seat onto your seat post, it is a straightforward, easy install. If you are asking how to actually use the seat, that is also very easy to explain. Can you please clarify what you specifically need instructions for. Bicycle seats do not usually come with instructions, as one can see how to install a seat by simply removing the old seat. If you use an adjustable wrench, or alternately an open ended wrench to remove the existing seat, you can easily install the new seat yourself. Be sure to firmly tighten the rail clamps underneath the seat (using the bolt that is inserted through the u-shaped seat post clamp) so there is no shifting of the seat while riding. If you need additional information, please write back.
Thank you for using FixYa.
Jul 17, 2009 | Planet Bike Men's A.R.S. Anatomic Relief...
Mar 26, 2009 | Health & Beauty
Unable to remove seat to replace batteries
Sometimes it just takes two really strong people to remove these seats. Especially if it is that old. I`m not saying damage the chair,but i`ve had some that were almost impossible to remove.
Mar 17, 2009 | Electric Mobility Shoprider Electric Power...
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
