Question about Frigidaire Refrigerators
Freezer not working and refridge is slowly getting warm
  • Frigidaire Master
  • 4,654 Answers
Freezer not working and refridge is slowly getting - ee50913c-9f3a-4825-9c86-8d01b3a2f831.jpgModel Number? Placing a model number here with and saying more about symptoms increases your chance at having a solution to the problem. I am here if you have questions, Thanks
Sea Breeze
Posted on Oct 16, 2013
  • 531 Answers
SOURCE: Top shelf of freezer is warm. Icemaker not working.
check your defrost
Posted on Apr 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: running warm. how do I recharge freon?
There are no service valves on refrigerators for charging.(They must be added).
It may not be a refrigerant problem.
Is the freezer fan motor running?
Is there a frost/ice buildup on the back wall of the freezer?
Is the compressor fan motor running?
Is the compressor Running?
These are the first steps to verify before suspecting a refrigerant leak.
Posted on Sep 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: Our freezer has started to slowly warm up. The
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jan 06, 2010
  • 256 Answers
SOURCE: Bottom freezer frosts up,top refridge gets warm
It sounds like you have a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Posted on Apr 13, 2010
  • 949 Answers
SOURCE: Frigidaire White 16.5 cu. ft. Top Freezer
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Posted on Apr 18, 2010
Frigidaire refrigerator - Model #FRT21BHscW2 manfuactured in 2004 has stopped cooling - freezer unit works - icemaker works - fan is running and compressor is warm - unit is clear of dust and particles. ...
Hello
There is a plastic duct work leading from the freezer to the refridge.Check that there is nothing blocking this ductwork.Also check fan in freezer for operation.
Have a look a refridge door seal also make sure it has no cracks or is not coming off.
Jun 13, 2011 | Frigidaire Refrigerators
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridge not cooling in freezer or fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
May 15, 2010 | Maytag MSD2456G Side by Side Refrigerator
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
FREEZER WORKS BUT REFRIGERATOR SIDE IS WARM
check if fan that blows air to the refridge is working or vent clogged
Jul 24, 2009 | Magic Chef CTB1821AR Top Freezer...
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
