Question about Vehicle Parts & Accessories
Python car starter
I have a 2004 GMC 2500 Diesel Pickup, I have Owned it about A Year with no issues until now. It has a Python remote alarm and starter, that both had been working properly until now. Last week the probelm started. When you turn off the truck, take the key out of the ignition, and lock the doors - the radio, power windows, power mirrors, and dash lights all stay on, once in a while they all shut off when you remove the key and lock the doors, but then I come back to the vehicle hours later and they are all on again, before I even unlock the truck. I ended up pulling the windshield washer module in the fuse box under the hood, and with it removed the radio, lights, power windows all shut off when you remove the key, but the windsheild washers don't work or the Python remote starter, but the Python alarm still works. I was thinking that maybe the accessories that are staying on are possibly being back fed through the remote starter??????
    Novelist:
  • 94 Answers
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Posted on Oct 16, 2013
2 Suggested Answers
  • 131 Answers
SOURCE: remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
Posted on Apr 16, 2009
I have a used 2014 expl intercepter with python alarm. The remote is not functioning due to water damage. I have key to unlock the doors but the alarm will not silence and vehicle will not start.
unlocking driver door only silences a factory alarm. put the python in valet mode until you can get another remote. key on hold valet button for 5 secs and led should glow all the time.
Jan 15, 2018 | Python Vehicle Parts & Accessories
Is 448V remote compatible with Python Car Alarm?
if its lit solid that usually means a problem with the system... so the alarm portion is most likely not active... or it might simply be in valet mode... without knowing the model of your car that's the best I can offer...
May 05, 2016 | Python Vehicle Parts & Accessories
Python alarm
The truck thinks you are trying to steel it. It needs to be reset ypu will need tocontack python and they will help you rest it.
Aug 14, 2014 | Cars & Trucks
Python alarm (460 HP) will not lock doors
The lock button in your remote may be faulty.
Nov 13, 2013 | 460HP Security System
How can I find a users guide for a Python 473P remote starter?
473P is the part number of the remote. 473P is the original remote for a Python1200XP alarm. I have the users guide.
Aug 14, 2012 | 473P 3-Button TX Remote
I recently installed a python 872 on my 2002 maxima. Now everytime i use the remote start and open the trunk the car shuts off and restarts in about 10 seconds. I had other dei alarms and never had that...
It's possible that the installer has the engine monitoring option programmed for voltage and, the unit sees a drop in voltage when operating the trunk...causing the remote starter to shut down. If so, try programming the unit for tachless instead or, hook up the tach wire.
Jun 10, 2011 | 872 Responder LE Security Remote Start
I lost my key with the python remote on it and when i use my spare key i cannot turn the alarm off what do i do.
The python alarm has a manual alarm disable. Upon entering the vehicle, turn ignition on, press and release valet switch. You should hear two chirps confirming that the alarm is disabled. Start the vehicle.
Oct 09, 2010 | Python Vehicle Parts & Accessories
Python car starter 951
unlock car via remote Push and hold F button for about 8 seconds until it says setup remote on the screen Use the aux and remote start buttons to scroll to CLOCK and then use the F button to access menu.
Apr 06, 2010 | 991 Responder LC3 SST Security/Remote...
Vehicle Parts & Accessories Logo
236 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
