Canon ir2016j change paper size drawer 1 - Office Equipment & Supplies
2 Suggested Answers
  • 92 Answers
SOURCE: My machine Canon iR2016J Problem: Change
hello.
on the cassette you must change to a4.
Posted on May 23, 2011
Open your drawer, you can see blue colored lever with arrow. Point that arrow to the size you want to use on your drawer. I pointed the arrow but nothing done.
If you are using the copy function from a computer, you have to set the paper size in the program. Most of those set the paper size to 8.5 by 14 inch
Feb 25, 2017 | The Office Equipment & Supplies
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
How to change paper size to a4 for drawer 1 of ir2116j canon
can do Change a4 first 0+8 paras after 225 and select any size [1] drawer [2] drawer 225 size select after enter up
Jul 09, 2014 | Toshiba estudio 255 Copier
My photocopier canon iR2016j is in A4R i want to come back to A4 in drawer1
just slide the slider in front of the drawer to A4. u have to open the paper drawer to do so
Aug 09, 2011 | Canon iR 2016i Black and White Copier
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Oct 24, 2010 | Canon imageRUNNER 1023iF Black and White...
Just want to know how to get the machine to know I want to change paper size. Am in an office that has lost the book
You can always download the user manual at Canon website. Try here: http://support-ph.canon-asia.com/
Goto Additional Function > Common Settings > Reg Paper Size > Drawer 1 > (Select the size of paper)
May 19, 2010 | Canon imageRUNNER 1023iF Black and White...
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
jasbo
jasbo
