I can not formate my computer with hard drive Seagate st32122A . it says pri master hard disk failed . Any Help please . link of hard drive picture . https://docs.google.com/file/d/0B3sP4XPmS-X5b1E3YlU0TTRySlk/edit?usp=sharing
  • 30 Answers
The hard drive is an IDE drive. that indicates aging. theres high probabilty of its failing.
Posted on Oct 16, 2013
Testimonial: "I think I should buy new hard drive because it was my antique hard drive from my very old computer ."
3 Suggested Answers
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Posted on Jul 24, 2009
SOURCE: Seagate 500GB FreeAgent GoFlex Hard Drive it didn't appear on my computer
RESOLVED!
Just because this starts with the same steps as other solutions does not mean it ends with the same fix.
1. Click Start
2. Right Click Computer: Select Manage.
3. The Computer Management Dialog box will appear.
4. Select the Disk Management Icon located in the right pane of the Computer Management Dialog box.
NOTE: Under volume you will NOT see the Seagate Drive.
5. underneath the volume pane you will see Disk 0, Disk1 and so forth. look for the Seagate drive ... mine was Disk 2.
6. Right Click on the Drive: Select Properties.
7. The "Seagate FreeAgent GoFlex USB Device Properties" will apear. Select the Driver tab.
8. Select the Uninstall Button.
9. Unplug your Seagate external hard drive and plug it back in. This should re-install the Drivers and it should work like it use to.
P.S. Sorry for the bad grammar\spelling.
Posted on Oct 09, 2012
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
My hard disk is not formatting
Go to the manufacture website, www.seagate.com Type: format hard drive.
May 05, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi i need to copy files from my macbook to my seagate hard disk which is in ntfs format.. it says it is write protected... help me...
the ntfs format is windows operating system format...
MAC will not recognize this format...
You need to format your hard disk according to the MAC OsX from your MAC computer...
Dec 13, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
I got a seagate external drive 500 GB all my documents and picture are inside , any computers recognize it ,please help.
The unit has two major points:
* the disk-drive
* the USB-to-disk-drive adapter
So, disassemble the unit, and remove the disk-drive,
and connect it as a 'slave' drive in a desktop computer.
If it works, then that adapter has failed.
See: http://www.canadaram.com/3_5_sata_enclosures.htm
to buy a replacement enclosure for your disk-drive.
Oct 06, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Trying to format a seagate hard drive, it gets to 100% but fails
well..when a partition is bad, only two options. remove it or format it(I don't recommend either. can you run a disk check from my computer, tools first, to see if the drive integrity is any good?
Nov 29, 2009 | Seagate Computers & Internet
Hard disk drive in slave position
Check your jumper settings... Following link is for your hard disk ST3160021A instructions.
http://www.seagate.com/images/support/en/us/cuda_sata_block.gif
Good Luck :)
Feb 21, 2009 | ASUS P5GD1-VM Motherboard
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Help me
go to my computer icon, right click, then click manage, then disk management; choose your hard drive you have just fitted, click on it then choose format or activate, choose as active.
Sep 08, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hardrive Partition Is corrupt
As i review your explaination, there might be a problem in your hard drive. There so many problems i encountered in the hard drive i encountered like that. However, some problems can be fix using your solution and the other can be fix by replacing the BIOS Battery, and sometime the error in the hardrive is cause by a memory fault. If you are sure that the memory, motherboard, and the bios battery is good and working properly. I recommend you to replace your hard drive that the inconsistency problem will be fined.
Please do testing of your hard drive by connecting it to the other system.
Feb 01, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
