SOURCE: ipod Nano 1st gen 4gb. Headphone jack signal in mono, not stereo.
most likely headphone jack is broken. option one is to take it to the apple store and have them repair it. option 2 is to go on e-bay and buy a replacement jack and try to do it yourself. best option is to sell it on ebay as broken/needs repair. Someone who knows how to fix them will buy it from you and you can use the money you get to buy a good used working iPod. There are always tons of nanos for sale on ebay.
SOURCE: ipod classic 160gb
I had the same problem. Try this: Toggle first Hold Button, push to Hold then leave it Unhold. Then long press Menu Button and the Center Button together for 10 seconds. Voila! There solves your problem.
SOURCE: no sound through headphones in ipod shuffle.
Player may require formatting. Try after formatting.
SOURCE: my Ipod Classic 160GB has no radio
The iPod Classic OS is same as the Nano. However, it looks to be so close as to come with the same settings checks off. The code to run the FM tuner is on the Classic and should have been disabled but Apple must have forgotten to turn it off.
SOURCE: i pod wont play sound on the left speaker or
if you have already tried a new pair of headphones , and still have same problem . you probably have a bigger problem , i had the same problem with one i bought from pawnshop . i immediately took it back knowing the problem was wear and tear on the audio out jack for headphones . usually happens when people carry there ipod in there pocket and are active , the audio headphone jack ends up breaking or bending insdie . this should work work > http://www.amazon.com/Cables-Go-35508-iPod-Compatible-Connector/dp/B000J022G6 AND THiS http://www.amazon.com/Cables-Go-35508-iPod-Compatible-Connector/dp/B000J022G6 YOU COULD ALSO CALL APPLE to see if they jave anything else like this.
