Question about Epson Viewsonic ViewPanel VE150M Monitor
My monitor screen stays on at start up for a few seconds, then turn completley white. Ive tried restarting, shutting down, changing monitors. Whats wrong?
    Problem Solver:
  • 7 Answers
If it happens with multiple monitors, maybe it's not the monitor that's the problem: your graphics card might be dead, and that's why it turns white.
Posted on Oct 16, 2013
2 Suggested Answers
  • 286 Answers
SOURCE: viewsonic ve150m problem white screen
Are you still using the same computer that was set to 200Hz? If so, start Windoze in safe mode and reset the display properties to 1024 x 768 60Hz. Reboot the computer and everything should be OK.
Does this model use an external ac adapter or an internal power supply? Twice I have seen a white screen caused by bad capacitors in the power supply. They may look good, but you should replace them anyway. Look in the 2ndary circuit of the power supply, you should see some capacitors that are (for example) 220uF 16 to 25V, 470uF 16 to 25V, 1000 uF 16 to 25V (all those capacitors could be 16V or 25V). Replace them and try the monitor again.
If it uses an ac adapter, try a different 12V adapter. Make sure it has the same or higher amperage rating. If you can't find one, you will have to measure the power going onto the board inside the unit while the adapter is plugged in and the monitor turned on. If it is less than 12V you need a new adapter.
If none of this helps, the panel or main board may be damaged. In most cases these two parts cannot be repaired.
Posted on Jan 22, 2009
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Screen is on, but does not appear to be on
The monitor was broken. I returned it to the vendor for replacement. Your tech did not seem to feel it was a monitor problem and only focused on the video card - although I asked him directly regarding his confidence of it being a videio card problem versus being a monitor problem.
I will not use your service again.
Mar 21, 2009 | LG 22" FLATRON LCD Monitor
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
May 12, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Nov 19, 2005 | Sylvania L181 18.1" Flat Panel LCD Monitor
Epson Viewsonic ViewPanel VE150M Monitor Logo
57 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
