Question about Plantronics Blackwire C320-m
Blackwire C320-M is not detected - Plantronics Blackwire C320-m
Hi, where can i find drivers for my Plantronics Blackwire C420-M, please ?
Here is the link; http://www.plantronics.com/hk/product/blackwire-400
Just click on software and then get its drivers and software.
Wish you best of Luck
Aug 13, 2012 | Acer Iconia Tab A50110S16u 101Inch HD...
\\the cables leading to the earpieces on my Plantronics Blackwire C420-M are hopelessly twisted. Is there a way to detach them to straighten them out?
Kim, sorry to hear about your dilemma. The cords cannot be removed. If they're twisted, you're only choice is to try and weave them back and forth around the headsets to see if they'll untangle a bit. It has been done with some success on other models. It'll take some patience but like an old sea captain once said: "Patience is a virtue, possess it if you can? Seldom found in woman but never found in man." So you have a better chance than I would :o).
Good luck from Headsets Direct!
Dec 21, 2011 | Plantronics Blackwire C420-M Headset
I need to know what splitter I can use for a Plantronics Blackwire C220 headset. I need to be able to plug in 2 headsets and use one to listen only and one to talk and listen. Please tell me what splitter...
There is not a USB splitter for computer headsets like the Plantronics BlackWire C220, you would have to go to a commercial grade headset to have that function. You can use any of the Plantronics "H-series" headsets with the Plantronics Y-training cable (model 27019-03), along with a USB adapter like the Plantronics DA40 or DA45 for training purposes.
Sep 14, 2011 | Plantronics Blackwire C220 Headset
I can hear, but no one can hear me when I speak.
Make sure the Blackwire C420-M is the default device selected in your Sounds and Audio Device Properties under Sound recording.
Jun 10, 2011 | Plantronics Blackwire C420-M Headset
Hi please help i cant find the specs for the C320
Not much - I saw one quote at 40, one at 50 watts rms. Strange that the manual doesn't include specs.
http://www.amazon.co.uk/Nad-C320-BEE-titane-Amplifier/dp/B0001HYIMS
May 11, 2010 | NAD C320 2-Channel Amplifier
"NAD C320 powers not really on and input selector doesnt work".
Hi..
You will need to find a tech in your area. Check the web
Mar 30, 2010 | NAD C320 2-Channel Amplifier
Where is the circuit breaker or fuse on a Kenmore Gas Dryer?
no heat usually means your only getting110 volts into your dryer.....you need the full 220volts to run heaters....with voltage meter you checkwires on the plug OUTLET...or inside back cover REDwire to WHITEwire =110v.........BLACKwire to WHITEwire =110v.....REDwire to BLACKwire =220v. you probably have aBAD 220V. 30 amp circut breaker..or if still using FUSES one is burnt out (In house electric panel) or burnt off RED or BLACKwire in back of dryer.....
May 09, 2009 | Kenmore 63942 Dryer
Mio c320 not detected by microsoft xp
The only thing it can be done is to rewrite the flash through j-tag method, but this must be done in service
Mar 09, 2009 | Mitac Mio C320 Car GPS Receiver
Mio C320 - How to replace battery indicator?
c230.files.wordpress.com/2008/02/battery-replacement-on-the-mio-c-230.pdf
go to that link and download the dpf and it'll explain everything
Feb 10, 2009 | Mitac Mio C320 Car GPS Receiver
D-Link DSB-C320 driver required
i need a d-link dsb-c320 driver to use on my computer please
Aug 29, 2008 | D-Link DSB-C300 Webcam
Plantronics Blackwire C320-m Logo
123 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
