Question about Kenmore Dryers
Gas dryer took a power serge. motor circuit wont lock in.
  • 119 Answers
It would be helpful if you have the brand and model number
Posted on Oct 16, 2013
Dryer wont start
Is this a gas or electric dryer; helpful to know. The motor is not starting consistently? Focus should be on the motor and starting circuit. Possible bad connection, they need to be clean. Is there a starting relay? If a motor relay fails to disengage the start winding then the motor will overheat. Motor and motor circuit matches the symptoms described.
Jan 10, 2014 | Kenmore Dryers
Maytag epic dryer
Without seeing dryer and checking it , best guess could be main control board problem
Dec 08, 2013 | Dryers
Whirlpool frontload dryer trips circuit when started all of the sudden. Gas dryer, replaced circuit, must be dryer
The dryer should be on a dedicated circuit. Is anything else on the same circuit? Try plugging the dryer into a different circuit and see if it still trips the breaker. The breaker trips because there is either a short or too much power is being drawn for the size of the circuit. Check how many amps the dryer uses, and make sure the circuit is rated for that load. If the dryer needs a 20 amp circuit, and the circuit it is plugged into is only a 15 amp circuit, that will trip the breaker.
If all that is good, there is a problem with the dryer, either a short or the motor is drawing too much power, which usually means it is at the end of it's useful life and need to be replaced. If you are handy, there are sites you can go to which will show how to remove the motor. There are appliance parts stores which will test your motor, and sell you a new one if you need one. I have a 30 year old dryer that still runs, with it's 4th motor and 5th belt, if you are handy. The cost of a repairman to come out is probably not worth it after the dryer is about 10 years old, better to replace the dryer at that point. The new ones are much more energy efficient and do a better job than the older equipment, so they are worth the investment.
Aug 02, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer wont come on
Did the circuit breaker trip? If not You may have a bad internal fuse, motor, door switch, timer or start switch.
May 15, 2012 | Estate TGDS840JQ Gas Dryer
GAS DRYER WONT START
Most likely you have a bad motor or broken belt.
May 15, 2012 | Whirlpool WED5520SQ Gas Dryer
I need a knife cutter for my babylock imagine
try
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Apr 24, 2012 | Baby Lock Imagine
No power to motor checked continuity of main switch the door microswitch is brand new and has continuity so to has the spring loaded idler circuit breaker switch, dryer was running after pulled down and...
I know you have already checked but first things first: breaker is not tripped, have 220 volts at outlet, have 220 volts at terminal lugs of dryer, if yes to all then some motors have a switch on the motor, do not know if yours will, it is where the power plugs into the motor, one is a trip the other a reset. Now we get into the other aspects of why dryers will not start, since the door switch is eliminated, then it is on to the others, here is a website that will help, now if all checks good feel free to post, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 28, 2010 | Dryers
Whirlpool gas dryer WGD5540SQ it is getting power, drum does not turn, just hums when I push start button. I checked for blown circuit breaker, i' ve cleaned lint tray and checked vent to outside. I've...
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Whirlpool WED5520SQ Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
