Question about Fujitsu LIFEBOOK AH550 (FPCR33571) PC Notebook
Cpu fan noise - Fujitsu LIFEBOOK AH550 (FPCR33571) PC Notebook
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
There must be some dust on CPU fan that is why they start making noise, you can simply open the CPU take out the fan and clean it up by using any blower.
Posted on Oct 17, 2013
  • 422 Answers
Open up the laptop, locate the fan
carefully remove the plastic sticker on the center of fan, drop oil (better if car engine oil) just 2 drops into the center, put everything back together.
if still fail, possible its the ball bearing worn out. go ebay and get a replacement
Posted on Oct 16, 2013
My Desktop PC assembled is emitting quite a bit of noise. Whenever an application or a download is started, the cpu usage shoots up and the noise / vibration also increases. What can I do?
I would think the SMPS fan, sounds like it's not keeping your computer cool. CPU fans usually never cause much trouble, but maybe you could look into getting quieter fans.
Mar 17, 2015 | Computers & Internet
Fan noise
HELLO!!
BASICALLY WE CLEAN THE CPU FANS REMOVING THE CPU FOR MINIMIZING NOISE ... CAN U TRY THIS ???
Jan 03, 2008 | Mitsubishi HC3000U Multimedia Projector
Dell optiplex 760 tower fan noise problem
Its important to try and distinguish where exactly the noise is coming from the most typical example of this is the PSU fan (Power Supply Fan). The above also is very correct but its better to eliminate each point of failure.
May 08, 2014 | Dell OptiPlex 760 PC Desktop
The fan is making an annoying noise
Usually, this occurs when the fan has accumulated dust. You should clean the area with a blower where is the cpu fan. If the noise persists, you must have replace your CPU fan latpop.
Regards!
Feb 21, 2013 | Acer 15.6-inch Aspire 5735-4774 Laptop LCD...
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
Cpu fan is making much noise even i changed it.
First open your cup and clean the fan with vaccume cleaner.
and check the cpu fan speed if required change the cpu fan.
May 19, 2010 | Asrock 845GV (P4I45GV) Motherboard
Cpu
The noise is coming from fan friction and vibration. Running compressed air through fan components can help reduce noise pollution from dust buildup. Brush-less CPU/GPU fans are significantly quieter than the brush-motor powered fans that come with some factory electronics. Furthermore, some computer cases are designed with noise reduction in mind; Antec designed cases are know for being one of the quietest because they use patented bushings to secure the computer hardware. Moreover, make sure internal wiring is free and clear of all fan blades.
Mar 11, 2009 | Intel D101GGC Motherboard
Foxconn CPU fan making noise
It sounds like the fan bearing is shot, I'd recomend not using the computer until fan is replaced.
yes it is possible to replace the fan, i would recomend that you replace it with an aftermarket cooler. all you need is what kind of CPU you have, then find out what kind of socket it is, from there you can find the cooler you would like.
Jan 27, 2009 | Foxconn CPU Cooler Fan CPU Fan
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Mother Board Fan Making too Much Noise
There are 2 main reasons for the CPU fan to run noisily.One is that there is film of dust accumalated on the cooling fins thus not allowing air to circulate and cool the CPU properly.The second is that perhaps the fan needs to be oiled because the sleeve bearing has gone dry.The most common problem for a noisy CPU fan is accumalation of dust.You will have to remove the fan and clean it thoroughly with a soft brush.
Dec 21, 2007 | Asrock 845GV (P4I45GV) Motherboard
Fujitsu LIFEBOOK AH550 (FPCR33571) PC Notebook Logo
88 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
