Question about Panasonic PT-53TW54 53" Rear Projection HDTV-Ready Television
Power come on and off after some time
Tv power went off itself, then I unplug the power cable and left for a minute plug again and on the TV the came back on as nomal the off again itself after 2 minutes I did the same thing again and again there is no change pl help me to solve the above problem thank you
  • Panasonic Master
  • 8,617 Answers
Is the power light blinking? It should blink a number of times pause a second then resume blinking. Count the blinks then let me know also let me know the exact model number of your set.
Posted on Jan 20, 2008
SOURCE:
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Have colored lines at bottom of tv
Hello!
First: disconnect any signal source from your TV, including cable. Unplug TV off the wall or power strip. Let it sit for a minute or two. Plug power back in. TV might turn on itself, might not. Depends on configuration. Turn it on manually, using set's "power" button. Observe the behavior. Lines? TV need repair! Not an armature job. Lines gone? start to connect signal sources back, starting with cable. Observe the picture. No lines? Proceed to the next source: DVD player, and so on. At some point lines might return. Make note, what source causes the problem. Then, you may know what to do next.
good luck,
Alex.
Jan 10, 2012 | Panasonic TCP46C2 46 in Plasma TV
I have a Model TC32LX70 Serial MX72540116. I also have Verizon Cable. The TV set keeps going off and I have to manually turn it back on. Sometimes it will go off and cannot be turned back on but will...
Hello
If the power indicator is blinking on the front of the VIERA, turn off the TV and unplug all HDMI cables that are connected to the TV. Then unplug the power cable from the current power source. Try a different electrical outlet. Remove the power cable from the rear of the TV and plug it back it in (the power cable tab is inserted correctly when you hear a click).
Just unplug the tV from AC powwer wall socket, let it be at theis state for about 30 minutes, replugh the TV only, and check whether the fault rectifes. OK.
Apr 23, 2011 | Panasonic Televison & Video
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to [email protected]
Dec 06, 2008 | Digimate DGL26 Television
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
2000 Sony Trinitron TV - Ghost activity, off & on power, now dead
Check and replace the T'Con board. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 06, 2017 | Sony KV-27S42 27" TV
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Panasonic PT-53TW54 53" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
