SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
SOURCE: tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
SOURCE: How long should your iron last?
10 to 20 years
use distilled water
Testimonial: "I have, in the last 6/7 years had 2 Shark Irons, both did not last me 5 years. That is a far cry from 10 to 20 years. I was told to use tap water."
