Question about Vehicle Parts & Accessories
Lower controle arm making a noise on my nissan hardbody 2003 model
  • 43 Answers
Is your truck 4 wheel drive or is it a rear wheel drive?
Posted on Oct 18, 2013
Nissan hardbody 2.4 16v 2004 model have a ticking sound in cylinder head changed all the timing chains and guides. Please help I'm desperate
Hello Francois, the tapping sound you hear might be coming from a bad valve lifter, a bad camshaft lobe, a bent push rod, a broken valve spring, a broken rocker arm or the valves may need to be adjusted.
Oct 21, 2015 | Nissan Cars & Trucks
How do i straighten the chassis on my 2007 Nissan Hardbody 3000td pickup?
This needs to be done on a frame machine in an auto body shop. They have the means to realign the chassis to allow proper fit and alignment of parts. Any other means is inviting additional damage.
Aug 30, 2014 | 2004 Nissan Frontier
Hardbody 2003 user manual
Romeo, There are many different things that could be making this sound.
Lets start off with the simple stuff. A bad shock, shock rubber or Strut (similar to Shock) could be worn out and making noise as it moves to the end of it's travel.
The next thing is a front stabilizer ( roll Bar) bushings. The Stabilizer help control the roll from side to side while turning. This is a metal bar that runs from side to side under the front of the car and will have a set of rubber bushings that connect to either the lower control arms or the strut towers. If the bushing is gone or the bushing control rod is rusted or broken this will also make a noise when you hit a bump or pot hole.
The next possible option is that you have a bad ball joint. This could be a bad upper or lower ball joint. The ball joint is the ball and socket connection which holds the Spindle and tire onto the lower control arm. You can test this by lifting the care slightly with the jack, than place a large prybar under the tire, Prying upward and inward if there is any movement you should consider having the ball joints checked by a garage and replaced.
Lastly the lower control arm is mounted in rubber bushings. Although these bushing last for a long time and usually do not need replacing if you drive in an area with poor roads, or drive on gravel roads this will accelerate the end life of these bushings.
You should be able to remove the tire and visual inspect these bushings, They are at the connecting point of the Arm where it mounts to the K-Frame or sub frame of the car.
I recommend have your car taken to a service garage that has a hoist and have them visually inspect the front end. You can also just go to have your oil change and have the servicemen take a look generally for free to see if they see any lose or broken parts.
There are several other parts that could be causing the issue, including rocks stuck in the Front Springs, tie rod ends, or even a motor mount or transmission mount. So with all this said, If you have the ability to raise the car in a safe position (I suggest you use car ramps or jack stands) you can take some time to lift the front of the car and take a good look around.
Most of these parts a fairly inexpensive, but may be costly in labor to repair.
If you need more help please feel free to contact me.
Thanks for using Fixya.com
Oct 16, 2013 | Vehicle Parts & Accessories
2003 daewoo makes a popping noise when coming to a stop from drivers side frontend
check out lower control arm bushes rear bush moves was revised bush for this and check tie rod ends as well as stabiliser bar mounting bushes and link bushes all of these caused noises and was a revision in parts for all of these plus power steering restrictor to go in hose. Main one is lower control arm bush.
Aug 29, 2011 | 2000 Daewoo Lanos
I want to replace lower ball joint on my nissan altima 2001
Remove the castle nut on top of the ball joint that secures the ball joint to the spindle. separate ball joint/lower control arm from spindle.Remove lower control arm bolt attatching control arm to subframe/engine cradle. Remove control arm. Replacement is recersal of the removal. Nissan/Infinity ball joints can not be pressed out or in. They are replaced with the whole new lower control arm as one (On most Nissan/ Infinity vehicles, although some exeptions apply. Hope this helps.
Daniel G.
Oct 06, 2008 | 2001 Nissan Altima
Nissan 4004 se-r sentra making squeaking noise from front end
Need to help me out more,
What kind of squeaking - how fast - turning left or right - how hard.
Does it go away under any special conditions ie wet, hot, cool etc
Applying brakes make a difference
When hitting bumps or speed bumps
Give me a little more
Aug 01, 2008 | 2002 Nissan Sentra
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
