Question about Motorola Mobility SLVR L7 Cellular Phone
Shorted out battery while replaceing LCD, now phone will not come on
I replaced the LCD screen in the phone but i accidently reversed the silver shield that was behind the LCD. when i inserted the battery, the battery terminals touched the metal on the shield at the same time the phone was powering up. what can be done to fix it? alan
    Brigadier General:
  • 7,752 Answers
Replaced the battery and if you are not a tech you should take the phone to a mobile service center and have them check the phone for you.
Posted on Jun 04, 2008
How to extend the short battery charge on Zeepad
You can decrease LCD brightness to improve you battery time
Jun 30, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
How to remove lcd screen on kyrocera hydro
  • Remove the battery cover from the back side of the cell phone. Remove the battery from its compartment and set it aside.
  • Use the screwdriver to remove the Phillips-head screws from the back panel of the cell phone. You may also need to remove the antenna from its retaining slot and remove it from the cell phone if you can
  • Separate the back panel of the cell phone from the rest of the cell phone's body. Place the cell phone face up and then remove the cell phone's faceplate from the rest of the cell phone. This should leave the LCD screen, keypad and circuit board completely exposed.
  • Tilt the LCD screen downward and then disconnect the LCD screen's ribbon cable from the LCD screen and set the screen aside.
  • Repeat this procedure in reverse to replace the LCD screen and reassemble the cell phone.
Mar 17, 2014 | Boost Mobile Kyocera Hydro Smartphone
White display
The reason your phone is showing white display is because the flex of the phone is faulty.
  1. get the appropriate screwdriver (Torx 6 screwdriver),
  2. First remove the battery cover & battery. Remove the two screws you see.
  3. Run your fingernail around the join of the front cover and then remove the front cover.
  4. Now remove the four screws you can see.
  5. The top part of the phone (PCB and LCD screen) can now be removed from the middle chassis,
  6. A metal frame surrounds the LCD screen. It's held on with clips around the edge of the PCB. Unclip and remove.
  7. You can now remove the LCD screen. It's attached by a ribbon which connects like a plug and socket. Simply lift it upwards and it'll unplug.
  8. The ribbon which connects the screen to the panel you just removed is what needs replacement, it is attached to the screen so you have to replace the screen, if there is a way you can replace only the ribbon, that would do just fine,
  9. You can now replace the LCD.
  10. Reverse the whole procedure for reassembly.
Take care
Jun 24, 2010 | Nokia 6300 Cellular Phone
Replace lcd screen
How to replace LCD Screen on a Zinc II
1. Take out the battery
2. unscrew the four torx4/torx5 screws including the one under warning label but no need to touch the phone idenity label ;)
3. unscrew the two side screws located near top
4. take out pen and any card in device
5. carefully remove back (now you will be able to see the circuit board)
6. looking at the phone LCD down so you see the circuit board remove screws (small Phillips/ cross-heads silver in color).
1.top left.
2. top right.
3. middle right near small cable.
Now you should be able to move the circuit board (do not force apart).
The LCD cable and keyboard cable are attached to the underside of the board.
1. Slide the phone 50% open (but keep phone LCD face down so you are look at the board phone the (keyboard being closest to you than main speaker).
2. Carefully lift left side of board (you should see the cables) using a small screwdriver Very Carefully pry them off the board (the should pop off with no force needed).
3. Slide phone fully open and now you are able to see all 4 torx screws that hold the front part of the phone on just under the circuit board.
* Bottom 2 are in small cut out boxes just under to circuit board you may need to slide the front up or down to align with the screws.
*The top 2 you should have notice when you fully opened the phone in normal use and looked at the back of the LCD at top behind speaker.
4. The front surround and LCD and buttons will come off. Carefully remove from bottom near the navigation buttons.
5. The phone should now be able to divide into the two sections with cables.
6. Unscrew the the LCD and the cable 2 top 2 bottom for LCD - but you have to also remove the button ribbon cable.
replace LCD and reverse process
*the LCD cable needs to be pushed into the socket on the underside of the circuit board (this can be tricky so take your time).
*Note: the keyboard cable is similar to the LCD cable but it has a smaller socket.
Feb 02, 2010 | O2 Xda Zinc Cellular Phone
Screen broken
Nigel-
Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
LG KF700 LCD Display Screen Replacement
Nov 07, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
BLACK SCREEN WITH COLOURED LINES ON LG KF700. BATTERY WENT OFF, TURNED BACK ON AND HAD THIS PROBLEM.
Sounds like your lcd screen is damaged. Here is a link that shows how to replace the broken LCD Screen on the LG KF700. There are links to buy a new KF700 LCD screen
Aug 26, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Lens broken does anyone know where i can purchase one
Apr 16, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Replacement Screen for Pantech C810
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
May 29, 2008 | Pantech PG-3600 Cellular Phone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
