Question about Hoover HDV7FM Electric Dryer
Hoover VHC691B . Condenser unit goes out of shape and wont fit back in properly. Then water leaks from under machine. Already had one replacement unit from Hoover but its only lasted 6 months.
4 Suggested Answers
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
SOURCE: Where is the water tray in my hoover 6 condenser
Its located behind the grill at the bottom to the front...just slides out
Posted on Mar 23, 2010
Hoover tumble dryer - condenser wont fit back in?
I would need to be there to see what you have going on, sorry,.
Sep 28, 2016 | Hoover Dryers
I am replacing the door of my tumble dryer and I need to know haw to assemble.
photo graph it with ure phone then put it back togather in reverse order
Feb 06, 2015 | Hoover Vision HD VHC691B White Electric...
I have a hoover optima, and I have just cleaned the filter, when I put the filter back in, water leaks out from it.
CHECK IF YOU HAVE REPLACED THE COVER PROPERLY. IF IT DTILL LEAKS THEN YOU HAVE TO REPLACE THE GASKET.
Regards.
DON'T FORGET TO RATE MY SUGGESTION
Jul 06, 2011 | Hoover Washing Machines
How do you attach the upholstery tube to the main unit? thanks!
The larger fitting slides into the front of the dirty water tank. Remove the lid and either remove the duct, or lift it and tilt it forward on more recent models. The hose fitting goes in with the opening up, and the "V" shaped end down. After replacing the lid, push the round connector down onto it's fitting under the trap door on top of the nozzle, being sure it is fully snapped in place.
Feb 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Unit is leaking water on the left side and after we fill up the water container. We are placing it in the proper position but it leaks constantly. It there a service fix for such a situation? ...
Hi
If its leaking under the water tank, its this.
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it needs to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won't slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
If its leaking under the machine, its your boiler.
If its leaking into the dredge drawer, its the thiumbscrew in the brew unit, that holds the filter screen in.
If its under your drip tray there is a pocket behind the brew unit that has a cloged drain, just above the center of the drip tray in back.
Jan 07, 2011 | Spidem Trevi Digital Plus Coffee Maker
Dec 05, 2009 | Hoover Dryers
Hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Aug 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My ice machine does not make enough ice
Check the water filters first. Then check the condenser coils for dust and dirt. Determine which way the air goes thru the condenser coils and check on the side the air goes into. There are coil cleaning sprays that work good. If it is still slow, it may need gas. That will require a service call from a technician.
May 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoover HDV7FM Electric Dryer Logo
89 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
