Question about Whirlpool Electric Range
Our whirlpool ygy397lxus03 control panel has stopped working. First started out with a few numbers now all of them have stopped...it's 3 years old
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the "control board". Here is the part you need to order. Be sure to take note of where each plug wire goes. I use my cell phone to take a picture but you could draw it out just as well. Also, be sure to unplug the unit before doing any work on it!
Posted on Oct 16, 2013
3 Suggested Answers
  • 4 Answers
SOURCE: Whirlpool GY396 Oven not working at all
Call him back out. Bad panel. It happens!
Posted on Mar 12, 2009
  • 41 Answers
SOURCE: Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
Posted on Aug 28, 2009
Whirlpool microwave AVM 585 - none of the control buttons are working, except the number 1.
The electronics on your control panel have gone bye bye. That is why to this date I have always preferred the nukes with the old fashioned timer. They always work and when anything goes it is the little motor that can be easily replaced at nominal cost..
Newer is not always better. Might look better but .....................
Sep 14, 2015 | Whirlpool Microwave Ovens
Sanitizing has stopped working. 7 year old
It could be your heater thermostats wire or the control.if it heats during the dry cycle its probebly your control
Feb 28, 2010 | Whirlpool Dishwashers
Buttons #3 & 8 on control panel not working
Sounds like your keypad has failed and you need the fan circuit repaired on the control panel.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Add to that about $75 for the keypad.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 01, 2008 | Whirlpool GH7155XHS Microwave Oven
DIM LIGHTS ON CONTOL PANEL
I had the same problem dim lights nothing happens when buttons pushed. I went through the trouble sheet that was in the drying and it pointed me to a bad control board. After replacing the control board it work. Awsome huh. Not it did the same thing a few hours later. I was able to unplug and replug and it worked for a bit and stopped again well after a few times of that it stopped all together. I was kinda upset after spending 135 bucks on that. I didnt want to put any more money into this machine. I took the machine apart and checked all the connections and wires. Removed the front panel and took all the ribbon cables off and made sure those were good too, (didnt short out) everthing checked out. For grins i replaced the 30 amp circuit breaker. The voltage was there but maybe its not getting the amps. I put the drying togeter enough to see what it dose. I didnt want to risk the chance of messing up the control board i bought while doing this so i used the OLD ONe. ( board was sitting on the dryer tub not bolted down). Well low and behold it works. I have been testing it for about 3 hours now. turning it off and on. change the setings on the dryer and so far it is still working. Before it would have messed up already.
Jun 30, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GHW 9400P
Hello! your problem is the motor control unit,MCU.
or the central control unit,CCU. Try unplugging the washer for a few minutes sometimes that will reset the unit.There is a tech sheet inside bottom of the washer cabinet.If youre not sure, may need a service tech.
Dec 17, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Electric panel not working
you have a common problem for that oven the key pad fails from wear try to find a replacement it should be fine after that.
Sep 19, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Whirlpool  Electric Range Logo
87 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
