Question about Eureka 431A Optima Bagless Upright Vacuum
How do you get bottom cover off to get at the brush---removed all screws and still not able to open bottom
  • 66 Answers
Not sure if this is any good but here is a link to a youtube video, showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Posted on Oct 16, 2013
How do I change the belt on my Shark Liftaway
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Feb 22, 2015 | Shark Navigator Bagless Upright Vacuum
How to replace belt on lux 4000 vacuum?
The following is for most models of the Aerus Electrolux UR models.
Lay the vacuum on it's front so you can see the bottom of the powerhead as shown below. Befrore going further, hold your hand straight and move your hand across the opening for the brush. If the bristles don't make good contact, the brush also needs replaced.
Remove the four screws. Using a flathead screwdriver, place it into the two rectangle openings (shown with red arrows) near the wheels and gently pry on tab to release the top of the power head.
Flip machine over and gently lift back of cover which will release the front. Lift off and set aside.
This is what you should see. Remove the two screws at the ends of the brush. Check carefully how the ends of the brush fit in. Gently lift out brush. This is a good time to clean entire interior of the power head. Install new belt over motor shaft and teeth of brush: set brush into place. Insert screws. Check tension of the belt.
Replace cover of power head, being sure to settle front in just beneath the lip of the front of the base first. Press down until it "clicks" into place. Turn machine over and insert and tighten screws.
Jan 04, 2011 | Electrolux Vacuums
I have an Electrolux Genesis model upright. How do I get into it to change the belt?
rogerpotts_2.jpg Flip machine over and gently lift cover off and set aside.
rogerpotts_4.jpg This is what you should see. Remove the two screws at the ends of the brush. Check carefully how the ends of the brush fit in. Gently lift out brush. This is a good time to clean entire interior of the power head. Install new belt over motor shaft and teeth of brush: set brush into place. Insert screws. Check tension of the belt.
Your vacuum is now ready to use.
Jan 03, 2011 | Electrolux Vacuums
How to install carbon brush
You have to open the case. First remove the transparent plastic on the side then you will see screws on the bottom part of the transparent plastic. Unscrew them and from there you will open the machine. Remove the rexair cover and unscrew the screw that attaches to the 2 carbon brush. When you remove the carbon brush you will see a spring and the copper wire at the end of the brush. remove it and put the new copper wire from the new carbon brush to the contact passing thru the middle of the spring. Then screw it back tightly.
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to change the belt on an upright silencio
remove the 2 screws from the bottom...remove bottom cover.....pull the rotary brush straight down and out....put new belt in the groove on the brush then reinstall brush and put the belt around the metal rod thats inline with the groove on the rotary brush...put cover back on and put the 2 screews back in...thanks and have a great night
Jan 03, 2010 | Vacuums
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
Bottom on the vaccum the spin brush will not spin at all
Double check for anything that might be holding it from spinning (shoe lace, string, hair, ribbon, etc)
If the brushes are free to move by hand, you most likely have either a broken belt or a belt that simply came off the motor. What you'll need to do in either case, is open up the vacuum cover. The screws are usually located at the bottom of the vacuum (where the brushes are) and remove all the visible screws you see.
Most of the time (being that I don't know what kind of vac you have, that is enough to remove the top cover off for you to inspect either the motor or the belt which attaches to the motor. I know on my hoover, the belt slips off very easily, so I always need to keep my screwdriver handy to perform this.
Hope this helps.
Apr 19, 2009 | Vacuums
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Open the bottom of 6594
Remove the bottom plate covering the brush roll and belt, usually has some screw holding it on.
Nov 21, 2007 | Bissell 6594 PowerForce Bagless Upright...
Changing belt on hoover runabout
Found this info on the web...haven't tried it yet
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Sep 07, 2007 | Vacuums
Eureka 431A Optima Bagless Upright Vacuum Logo
42 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
