Question about Sony CDP-CX400 400-Disc CD Changer
I just picked up a Sony CDP-CX400 disc changer. When I turn it on (with no discs inside), the carousel keeps spinning back and forth. It doesn't seem to spin all the way around either. It just spins roughly one-third of the way one way, then spins roughly one-third of the way the other way. The "play" button isn't pushed. This happens just from turning the unit on without anything in it. The blue light inside keeps blinking throughout. The only thing that will make the carousel stop turning is to either power the unit off, or hit the button that opens the door, or strangely enough, insert a disc and play it. Yes, the unit does play, but if I insert a disc into, for example, slot #400 while the display reads another number (such as #390) and close the door to the unit, the carousel spins partially around and the LED display numbers rapidly ascend until they get to #240, then they stop there at #240 and the carousel just rotates partially back and forth with the display stuck on #240. But if I manually turn the big knob to #400 and press "play", the disc then plays. Then if I press "stop" the carousel finally stops spinning back and forth. In other words, unless the LED display is set to the slot that actually has a disc in it, the carousel will just spin partially back and forth without stopping, even without pushing the "play" button, while the LED display remains stuck on #240. Can you help me with this?
4 Suggested Answers
SOURCE: Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Posted on Mar 30, 2009
Beelz
  • 666 Answers
SOURCE: ALL SEEMS FINE BUT WON'T PLAY DISCS.
I would suggest taking a can of compressed air to the disk tray to ensure the laser is clear of all possible debris
Posted on Mar 30, 2010
Testimonial: "UPON REMOVING THE COVER TO DO AS YOU SUGGESTED, I DISCOVERED A BELT WAS OFF T0 THE DISC LOADER. THANK YOU"
  • 6771 Answers
SOURCE: cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Posted on Apr 15, 2012
Disc will not load on sony cdp cx400
Loader mechanism fault. Not engages the CD properly to desired tray section. Contact any service technician. The loader tray should be repaired, and this is not a user repairable fault.
Oct 17, 2014 | Sony CDP-CX400 400-Disc CD Changer
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
Player was moved discs fell forward. Now when the player comes on it makes a horrible sound. Can't get door to open
you're going to have to open the player by removing the top cover and returning the discs to their correct places on the carousel. If you've coded the discs' locations and disc names it will be a pain to have to re-code them, I don't know if the memory will clear if you take the discs out and power the unit up and it finds they're not there.
I believe the discs being out of place are what is preventing the door from opening. It's operated by a motor located under the right front of the carousel, and the only way to get it it is to remove the carousel.... which isn't hugely easy but it can be done, you'll have to take the top stuff off inside, unplug at least several of the cables etc so you can move the top board out of the way. Make sure that all the discs are back in their places on the carousel, OR removed, before you turn the unit back on.
Dec 02, 2010 | Sony CDP-CX400 400-Disc CD Changer
ALL SEEMS FINE BUT WON'T PLAY DISCS. FLASHING BLUE LIGHT INSIDE.I GET "LOADING ERROR" ON SCREEN, AFTER A COUPLE MINUTES. SONY CDP-CX400
Mar 30, 2010 | Sony CDP-CX400 400-Disc CD Changer
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Sony CDP-CX400 400-Disc CD Changer Logo
100 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
