Question about Microsoft 90873 Sidewinder Handheld Controller Pc Video Game Pad Gamepad
Drivers for 90873 controller - Microsoft 90873 Sidewinder Handheld Controller Pc Video Game Pad Gamepad
Missing video controller,multimedia controller,smbus controller,pci controller,ethernet controller
the driver should be on the disk supplied by your isp internet service supplier
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
hope this helps
Jan 13, 2011 | Computers & Internet
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
I HAVE A PACKARD BELL EASYNOTE ED1 AND IT RUNS ON XP PROF. I AM LOOKING FOR THE FOLLOWING DRIVERS:1 1. MASS STORAGE CONTROLLER 2.MULTIMEDIA AUDIO CONTROLLER 3.NETWORK CONTROLLER 4. PCI MODEM 5. VIDEO...
For the chipset drivers go to: www.intel.com there, you can search for the intel 852 / 855 chipset drivers. they also have the video controller driver ( Media Graphics Adapter ).
For the audio driver go to: www.viaarena.com there, search for the vinyl drivers there's only one listed. the version is v700b.
For the wireless network adapter you can search for the 2200BG driver on www.intel.com
As for the mass storage controller: it's a PCIxx21 flashmedia controller from Texas Instruments. search for the drivers at www.driverguide.com it may be neccesary to sign up. driver id = 869508
for the modem download this:
http://www.conexant.com/support/files/HSFac97_WinXP.zip
it's a conexant AC97 modem.
good luck.
Aug 30, 2010 | Computers & Internet
Sound device instal to my system
can you be more specific? i am assuming you dont hear any sound.
first off, make sure that you speakers are plugged in. (both power and to the sound card) because some speakers require ac power.
here is where the speakers go:
http://www.infernotech.com/ref_book/software4332arch/90873.php
at the bottom of that page, the green audio port.
second is the audio driver. which is more likely your culprit.
you will have to find out who made your sound card.
a standard pc has the sound card built into the motherboard, so your drivers will be provided for you by either the pc manufacturer, (ie, dell, gateway) or by the motherboard manufacturer, like biostar for instance.
if you dont have the driver disk, you will first need to find out who made the card. if your profficient in using a computer you can extract this information with a program called siw.
siw can be downloaded here:
http://www.gtopala.com/download/siw-setup.exe
once you have that information, you then need to find your driver.
you can usually get that from the manufacturer, for instance a intel chipset driver for your motherboard sound card from intel, or a creative labs sound driver from creative.com.
if not, your next best bet is to sign up for a free acount from driverguide.com.
driverguide is annoying, constantly trying to get you to buy products, but they have a very large driver selection. and you can get the drivers free there.
Jun 11, 2010 | Intel Computers & Internet
Please let me know from where i can download the following drivers for my Compaq Presario v2000 machine: 1. Multimedia Audio Controller 2. Network Controller 3. PCI Modem 4. Video Controller 5. Video...
I want drivers for multimedia audio controller and pci modem.Multimedia Audio Controller
3. PCI Modem
4. Video Controller
5. Video Controller (VGA Compatible)
Jun 26, 2009 | HP Compaq Presario V2000 Notebook
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
anand_anj2005@hotmail.com
Apr 12, 2009 | Computers & Internet
Need Driver
plz visit the manufacture website and download the drivers
May 22, 2008 | Compaq Presario R3000 Notebook
Missing drivers for compaq presario v2000 machine
Please let me know from where i can download the following drivers for my Compaq Presario v2000 machine: 1. Multimedia Audio Controller 2. Network Controller 3. PCI Modem 4. Video Controller 5. Video Controller (VGA Compatible)
May 07, 2008 | HP Compaq Presario V2000 Notebook
Hi i need to download drivers so my laptop will go on the internet,, its under device manager , the following are have a yellow question mark, ethernet controller , mass storage controller , multimedia...
i need drivers for my toshiba satellite M55-S3512. other drivers i have found from the toshiba web site but only the given below drivers i could not find.
1. Mass Storage Controller
2. Video Controller
3. Video Controller(VGA Compatible)
any one help from where i can find these drivers.
thanks
Feb 02, 2008 | Toshiba Satellite M55-S3512 Notebook
Microsoft 90873 Sidewinder Handheld Controller Pc Video Game Pad Gamepad Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
