Question about Car Audio & Video
Duravit 1 6 gpf 6 lpf
Toilet cistern 6lpf/1/6gpf toiet flushes then doesn't cut off water when cistern fills
  • 659 Answers
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
Posted on Mar 21, 2009
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
SOURCE: I have a Duravit toilet with a Geberit flushing
i think you have a snake in your bathroom lol
Posted on Apr 26, 2010
  • 150 Answers
SOURCE: even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
Posted on May 22, 2010
  • 5 Answers
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Posted on Jul 02, 2010
AquaSource High-Efficiency 1.6; 1.1-GPF (6.06; 4.16-LPF) White WaterSense Dual-Flush Elongated Chair Height 2-Piece Toilet from Lowes that won't evacuate the bowl during a flush.
The flapper may be closing before the tank is dumped completely. You can verify this by observing flushing action with the tank open.
Apr 13, 2017 | Maximum Home
Duravit toilet cistern fills slowly
make sure the toilet shut off is all the way on (if there is one) replace filler valve and should fill quite quickly.
Oct 08, 2014 | Duravit Duraplus, Two-Piece Toilet -...
Flush for solids does not have enouvh power for a good flush
The problem probably is in your valve which regulates output of water. Normally on these types of toilets, this is and can be the common cause.
Apr 19, 2014 | Duravit 0910100005 Happy D Toilet Cistern ...
I have a Duravit Starck 2 toilet cistern which is approximately 5 yrs old, recently water from the cistern runs constantly into the bowl. I have renewed the flush value without any success. I would...
Did you replace the flush valve or the flapper?
There must either be a problem with the seal between the two surfaces of the flapper and flush valve or the flapper is being prevented by the flush system to returning to make a seal against the flush valve after the water completes draining during the flush cycle or more likely water is draining through the overflow tube.
Make sure the sealing surfaces are clean and not damaged.
Make sure the flapper is not being interfered with and is able to return to the closed position to make a complete seal against the flush valve.
Check adjustment of the water fill level to make sure the water is not filling above the water overflow. If the inlet valve does not shut-off when the level is adjusted to the proper level the water inlet valve may need replacing.
The following videos may prove helpful.
Dec 22, 2010 | Home
Handicapp Toilet Bowl does not fill - up as high as regular toilet > very small amount of water in bowl after flushing ie> about 10 cuos of water.. JUST INSTALLED IT NEW YESTERDAY...
Wiith all due respect, the Drake toilet is not a regular toilet and doesn't sound the same as a regular toilet when you flush it. It is in the design that allows it use only 1.5 gpf instead of 3.5 gpf. A rather unique thing is that while it is scientifically calibrated to release 1.5 gpf, it does not empty the tank of approximately 1 gallon of water. Therefore if one feels the need for a little extra umph, simply hold down the flush lever when you flush until the tank is emptied.
Aug 04, 2010 | Toto DRAKE ELONGATED HANDICAPPED TOILET...
Why is it oveflowing continuously?
maybe your fill valve need adjusting, or replacing, or the flush valve is bad your question is a little broad so it is hard to pinpoint
Jun 29, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
