Question about Carl Martin Compressor Limiter Pedal Designed with Varible Threshold Compression and Attack
Carl martin compressor wiring diagram - Carl Martin Compressor Limiter Pedal Designed with Varible Threshold Compression and Attack
The serial number is 446412. Does not correspond to any Martin list on internet. How do I find the date it was made?
Contact Martin customer service.
heres their link
https://www.martinguitar.com/guitar-care/customer-service.html
Martin Guitar Customer Service Martin Co
Oct 11, 2015 | Martin Music
I have a martin d 18 serial number 1713264
If that's the correct serial number, it was made in 2013. The Martin serial number chart is at http://www.martinguitar.com/about-martin/the-martin-story/serial-numbers.html
Oct 01, 2014 | Martin Music
Hot drive n boost not working
It's probably just the switch, nothing big, get the new one and you can solder it yourself. Or just let someone who knows do that for you, it's a cheap and fast thing.
Mar 03, 2014 | Martin Carl Hot Drive 'N Boost Mk 3 Pedal
Litlle Martin LXME Tuner not working properly!!!
the only other solution would be an electrical short in the wires running from the tuning box to the input cable hole. take the tunner all the way out and make sure there are no loose wires. Make sure nothing is preventing the wires from making good contact.
Jan 23, 2012 | Martin Lxme Little AcousticElectric...
When plugged into my churches pa system through a direct box the volume gets really loud then really quite and then sometimes normal. I'm using a lithium battery
Talk to your sound man... It is possible he has a compressor on the line. A compressor adjusts the volume dynamically and delays tweeking and releasing as a setting. Your guitar should NOT run through a compressor.
Aug 08, 2011 | Martin Guitars Martin XC1T Ellipse...
I am trying to wire in the guitar jack on a Martin DC 16GTE. It has a white wire a red wire and a black wire. There is a selection for A Blend and B Blend. I have the red wire connected and it produces...
I know this is more of a referral than a solution, but I'd go right to the source and contact Martin's customer service folks. They should be able to either get you a proper "wiring diagram", or possibly just describe the jack wiring to you. They have a phone number and an email address posted at this link...
http://www.martinguitar.com/services/customer.html
Now if I had to guess, I'd say both the A & B blend wires probably both go to the "tip" connector of the jack (otherwise, it would require a weird non-standard setup to function properly, like using a stereo guitar cable or something, very unlikely).
Jun 09, 2009 | Fishman Music
The pick up on my son's Martin LXME won't work
Take it to a guitar shop and have them check out the soldering and connections within the guitar.
Martin has a record of cutting corners on their less expensive models.
Jan 13, 2009 | Martin LXM "Little Martin" Acoustic Guitar
Carl Martin Compressor Limiter Pedal Designed with Varible Threshold Compression and Attack Logo
19 people viewed this question
Top Carl Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Carl Music Expert? Answer questions, earn points and help others
