Question about Breville Fresca BES860 2Cup Coffee Maker
How do I remove the entire steam wand to replace it with the new one I have received?
Steam wand boils water but does not make any froth
Making froth with a steam wand is an entire technique. Also depends if it has a panarello or not
Jan 06, 2015 | Saeco Odea Giro Plus Coffee Maker
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats http://www.bluestarcoffee.eu/ascaso--boiler-thermostats-x-2-193-p.asp
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
http://www.bluestarcoffee.eu/ascaso-gasket-kit-dream-arc-basic-114-p.asp
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
The steam wand does not produce steam, merely drips water with a little push of air at the end. I am not sure how to take the entire wand off, however the temp probe and the cover at the bottom of the...
leave the wand in place and disconnect the teflon hose that connects to the wand then press the steam button again.. check presure... you could have a bad steam valve
Feb 17, 2011 | Schaerer Siena Espresso Machine
I need a replacement steam wand sleeve
I called them about the same problem, they can only sell the entire wand assembly, not the teeny washer that I lost. $35. If I knew what it looked like I wonder if I could find something at a hardware store.
Jun 06, 2009 | Saeco Starbucks Sirena Espresso Machine
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Feb 27, 2009 | Gaggia Carezza Espresso Machine
Steam wand loose
you can tighten the steam want with a wrench. At the top of the wand just before it enters into the machine you see a "nut" use this to tighten or loosen the wand
Jan 05, 2009 | FrancisFrancis! X1 Espresso Machine
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Not making steam
hi tried99X. couple of possibilities: have you made sure steam wand is completely clean? allowed adequate time for water to heat? try looking inside: unplug machine, remove the ten screws on the bottom and gently lift away base: it does have wires connecting it to rest of machine so be carefull not to yank on them. locate the hose leading from the pump to the steam-arm (may be hard to see; use a good penlight and a small telescoping mirror if you have to; Autozone & other auto parts stores sell them for a couple of bucks-if you don't want to take off the entire casing of the machine. does the hose look okay?) also see if the pump has vibrated out of position. also, when's the last time you descaled? good luck!
Dec 07, 2008 | Breville ESP8XL Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Breville Fresca BES860 2Cup Coffee Maker Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
