Question about Panasonic (KX-TG1032S) Phone
Flashing signal icon - Panasonic (KX-TG1032S) Phone
Why Dell icon flashes continuously on the screen when switched on in Dell IN1930f Monitor?
Press the Menu button on the monitor.
  • If the menu comes up, you've got a problem with the video signal.
  • If no menu appears, then there's something gone pear-shaped inside the monitor, possibly the power supply.
If you've still got the documentation for it, check the troubleshooting guide, usually found at the end of the manual.
Sep 25, 2016 | Dell Computers & Internet
My gionee P4 is not getting mobile signals
if your gioneer p4 is not getting mobile signal then it may be problem from the kitkat and or the ios so you have to upgrade it by following these process https://www.dropbox.com/s/7e7ztb5v9lq2b6e/Materialmod_by_Swisscarter.zip?dl=0......little guide on it Material ROM users download that file a flash via recovery!! See proofs
Signal icons to the left
Signal icons like iOS style
Framework mods too
Material ROM v3 users only
Jun 19, 2016 | Cell Phones
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Security key on and bike wont start
First, open fob and make sure battery is making good contact and no corrosion on contacts.
Also, you might need a new fob battery.
Finally, if you know the security code, you can disable the security system.
DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Mar 16, 2013 | 2008 Harley Davidson FLHX Street Glide
I HAVE A 2007 HARLEY DAVIDSON CLASSIC SOFTTAIL. SECURITY SYSTEM PROBLEM. I HAVE REPLACED BATTERY & KEY FOB STILL COMPUTER WILL NOT ALLOW ME ENTRY TO DISARM & WILL NOT CRANK. DID STEP BY STEP OWNER...
If you do not know the security code, you can reset it to your own choosing.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Feb 28, 2013 | 2007 Harley Davidson FXSTC Softail Custom
Changed battery on my 2007 streetglide and system not recognizing my fob so not starting
Yes, you do need to take it to dealership to match the fob.
BUT, to get it to the dealership, you can bypass the fob IF you know the security code.
Feb 23, 2013 | 2007 Harley Davidson FLHX Street Glide
Need to bypass the security fob. Won't start
You can bypass the fob IF you know the security code.
Nov 08, 2012 | 2007 Harley Davidson FLHX Street Glide
Lost key fob how to turn off alarm?
You'll need the PIN number.
If you don't know it, you'll have to change it to a 5 digit PIN number you select.
Nov 06, 2011 | 2008 Harley Davidson FLHR Road king
Lights on the bike flash and the bike will not start, can anyone help?
If you have a factory security system with the sensors located inside the key fobs you probably need to replace your fob battery.
Aug 08, 2010 | 2008 Harley Davidson FLHX Street Glide
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Panasonic (KX-TG1032S) Phone Logo
19 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
