Question about Compaq tc4200 Tablet PC
Usb port failure - Compaq tc4200 Tablet PC
    Scholar:
  • 60 Answers
what type of device you are trying to connect on your tablet PC? have you tried using another usb cable?
Posted on Oct 16, 2013
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Charging port not working. How can I fix it
If it's a mini-USB charging port you could have damaged contacts on either your USB cable or the USB port itself. You should try another cable first hoping that it's only a damaged cable. If the new cable doesn't do it then it's probably the USB port itself. If that's the case, you probably have to take or send it in for repair.
Jul 28, 2015 | Tablets & eReaders
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
What do ido to make my kindleD00901 operational SCRREN showing critical battery
The nice thing is, that the Kindle/Amazon charger (Ac adapter) is clearly marked as being an Amazon/Kindle charger.
So, here's what you do, perform the hard reset of the Kindle (slide and hold the power switch over to 20+seconds; count slowly; release, then connect to your Amazon/Kindle AC adapter. Then leave it connected for 30+minutes; and should the battery charge, the Kindle screen will return to normal.
Alternate step to try is; if you don't have the actual Kindle AC adapter, you will need to try to charge via the USB port from your computer.
The trick here is, that the Kindle takes longer to charge direct from a computer USB port, and the computer has to be left on the whole time and CANNOT go to sleep, as the power to the USB ports might be turned off.
Also, it's best if you connect to a "powered" USB hub, or the USB ports found at the back of a computer tower (not the front USB ports as most of the time, the front ports do not supply enough power for Kindle charging).
May 25, 2014 | Amazon Kindle 3G
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
I can't transfer picture from camera to my compter
which dell tablet? what operating system? are you using usb port? have you tried more than one usb port?
if so usb port drivers get corrupted in windows xp and xp media center alot. my suggestion is reinstall the chipset driver.
May 21, 2010 | Dell Tablets & eReaders
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tablets & eReaders Logo
22 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
