Question about HHB Radius 50 Tube Amplifier
Stage 100 blowing fuse,loud hum - HHB Radius 50 Tube Amplifier
    Genius:
  • 1,175 Answers
If you are not a tech , take to someone who is please.
One or more output transistor has failed and is dumping DC voltage into your speaker. If that keeps up , it WILL cook the speaker
Posted on Dec 16, 2014
  • 4 Answers
Hi,If your blowing fuses then the problem is most likely to be faulty bridge rectifier or darlington output transistors.All readily available and not too expensive.Circuit diagram on Fender site or net easily found.Thanks Fender good customer service.
Posted on Jun 08, 2014
My problem is with the inside air handler of a Ruud system. Would watevers blowing the fuse be making the transformer hum real loud? Or is the other way around?
If the low voltage fuse keeps blowing a short circuit exists somwhere in the low voltage wiring. The hummimg could be the transformer loose or possibly the motor.
Dec 15, 2012 | Heating & Cooling
I have a split system trane I16i 5 ton making a loud humming noise when it is in the first stage once it kicks into 2 stage it sounds ok
Trane has issues with loudness of their 2 stage system. Not saying its normal just saying its common. If you notice cooling ok in both stages then it can be narrowed down to refrigeration flow is noisy or a solenoid valve is loud.
Aug 20, 2010 | Heating & Cooling
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
Loud speaker hum then blows fuse
Hi there. The final output IC (big and black with 15 pins? attached to heat sink) is shorted and needs to be replaced. If you can still see color bands on R63, it should still be good.
Thanks
Paul
Jul 12, 2009 | Music
The power fuse blows as soon as the unit is plugged in
There is a problem with the amplifier within the sub. Many of these units never completely turn off. They are often set to automatically startup when a signal is detected. This may be the case here. The loud hum as a defect in the output amp section. At this point you probably have a blown amp section. The "protection" for this is to cause a dead short that will open up the fuse. This unit will require service. It is unlikely that any service info is availabel to the general public either.
The fix could be simple, but without seeing the unit, I can not state that for sure.
Keep us posted.
Dan
Feb 03, 2009 | Dual L8SW Subwoofer
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
Car audio
The amp has a short in it. It is common that the output stage becomes damaged for various reasons on many of these amps. The output and driver stages will have to be serviced.
Most of these failures are from defective speakers loading the amp, or there is a short somewhere, or the amp was over-driven by being played much too loud.
Jerry G.
Apr 29, 2008 | Car Audio & Video
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
M-Audio DX-4 speakers blowing fuses
could be a problem with the wires? good luck
Feb 10, 2008 | M-Audio Studiophile DX4 Computer Speakers
Noise when it turns on
have you checked your music source? Some systems like computers have a sort of output first before normalizing, which isn't your powered subs or powered amps problem. Try plugging in a regular solid state player like an ipod if the humming is still there when automatically turning on or off...
Dec 06, 2007 | JBL PB12 Subwoofer
HHB Radius 50 Tube Amplifier Logo
179 people viewed this question
Top HHB Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
